Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: Which kit to get?
    Dec 2004
    Question Which kit to get?
    I am good with electronics so any conversion like using the computer power source to drive the system is no problem at all.
    I want to know which kit will suit my needs better. I want to engrave circuit boards. I just picked up a cross slide table for my x and y axis http://www.harborfreight.com/cpi/cta...itemnumber=538 for 20 bucks so if this is a bad idea let me know and I wont use it.
    Here are the electronic kits I found so far
    hobbycnc's "3 Axis Package With (3) 80oz-in Steppers" from http://www.hobbycnc.com/cncpackages/...g/4aupcpkg.htm ?
    and
    stepperworld's http://209.41.165.153/stepper/sp3HT.htm
    is this worth the extra 80$ dollars?
    Nick
    Mar 2003
    Shelby Twp, MI....USA
    IMO, the HobbyCNC is a much better setup. You'll get a lot more speed, and it's much more efficient. But you really want to use at least 24V for best performance. And before you say speeds not important, trust me, it is.
    Dec 2004
    great, thanks for the info
    Sep 2004
    Be careful those vises hav alot and i mean alot of backlash. But of course you probably are changing that.
    Dec 2004
    i wasnt planing on change anything, what part do you recommend changing? Does backlash mean that it has alot of play?
    Nick
    Aug 2003
    Farmington, Missouri
    Backlash... the enemy of precision.
    Quote Originally Posted by NickLatech
    Nick
    Nick,
    You'll find a very good article on backlash here:
    Backlash
    I hope that helps.
    Good luck.
    jimmyd7
    A one eyed man is king among the blind.
    Dec 2004
    thanks, yea there is some backlash in the table. I did a search for cross vice and backlash, but didnt come up with any results. I might try and work with it as-is.
    Nick
    Aug 2003
    Nick
    Nick,
    I believe that some software has backlash compensation tools built in, but I don't know how affective they are. If someone else has experience with it please help Nick out.
    Good luck.
    jimmyd7
    Dec 2004
    Thanks, it actually has what i think is alot of blacklash. I have to turn it about 1/8 (5 something from reading the nob) a turn just to get everything tight to the actual table moves, its this way on both of the axis's and turning both directions
    Here is a pdf of the design.
    http://www.harborfreight.com/manuals/0-999/538.pdf
    I want to be cheap, but I dont want something that doesnt work. I would like to see about fixing the current system, but I will replace the stock 'screw' if that is what is required.
    Please inform.
    Nick
    Registered Torsten's Avatar
    Nov 2004
    U.S.A.
    For a cheap solution you may be able to keep the screw.
    There are a few home remedies to help reduce the backlash.
    I would call them and get a replacement Part for the screws
    Nut Partno. 13 and 22, then figure out a way to mount the
    additional Nuts side by side with the originals in a way that
    you can make some adjustment on there spacing.
    That is all you need for a cheap backlash free operation.
    Good Luck
    Aug 2004
    Moglice...look at how this is used by many professionals to reduce backlash....it's pretty amazing....I was kinda skeptical, but Home Shop Machinist has had a few articles on how a "seasoned professional" used Moglice to repair a lathe with excessive backlash. Just one of many ways to reduce backlash. You might determine the accuracy of the leadscrew by advancing 1 inch, 10 inches and 20 inches and measuring to see what the variation/accuracy is when you advance the table/carriage in one direction....it will help you determine if you should replace the leadscrew.
    Jan 2004
    Michigan
    and
    Nick
    Hi Nick,
    Here is a another design you might want to look at.
    http://www.embeddedtronics.com/microstep.html
    kinf@embeddedtronics.com
    Robotics, CNC, and Controllers
  • Page 1 of 2 12 LastLast
    1. Taig 2019CR + IMService Kit 404025 + Power supply?
      By Idle hands in forum Taig Mills & Lathes
      Last Post: 05-02-2005, 04:55 PM
    2. 4-axis unipolar kit
      By itsme in forum Xylotex
      Last Post: 03-02-2005, 06:26 PM
    3. CNC Retrofit - Kit verses turn on and go
      By MetDetect in forum General Metal Working Machines
      Last Post: 07-12-2004, 11:06 PM
    4. PC Based Hardware Controller Kit Needed
      By pmartin223 in forum General Electronics Discussion
      Last Post: 06-13-2004, 11:28 AM
    5. 4th axis plans or kit
      By seansear in forum DIY CNC Router Table Machines
      Last Post: 04-01-2004, 12:52 PM
