Old 04-12-2009, 11:54 AM
meck11 is on a distinguished road
Decent Limit Switch
Just started to cut my first item cheap limit switch triggers z axis limit error on mach 3 I can even tap switch with screwdriver and I
get a single pulse not enough to even light led on mach 3 but to go into reset any suggestion on decent switch or something that can be done in mach 3
Old 04-12-2009, 12:38 PM
knowell2 is on a distinguished road
Under Config -> Gen Config, upper right corner set debounce interval to 2000
Old 04-16-2009, 08:24 AM
re switch
changed it up to 5000 cheap switch still triggered
any suggestions on a good limit switch which wont trigger from vibration
thanks
Old 04-16-2009, 10:26 AM
Al_The_Man's Avatar
I doubt very much if it is the switch, you can debounce all you can, but if noise is constantly present then debounce is futile.
I would look at grounding and bonding the various boards and supplies, is the switch going directly into the parallel port?
Old 04-16-2009, 10:40 AM
switch
no Its the vibration If I tap the switch it triggers
I opened one it looks like a leaf spring it seems to glide I can see why it triggers so easy
what Iam asking is are their better switch made and has anyone else had this
problem
thanks
Old 04-16-2009, 11:23 AM
Al_The_Man's Avatar
Honeywell Microswitch are usually quality items, even the open frame style.
I generally use the 914CE series, but these are industrial strength, Omrom make an equivalent also.
limit switch- home switch normd CamSoft Products 1 05-16-2008 06:56 PM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 07:58 AM
Is it possible to use the home switch as the limit switch as well? Darc Mach Software (ArtSoft software) 2 10-23-2005 12:50 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
