Thanks for doing that. I really appreciate you going to the effort for the rest of us.
That is a beautiful guide. Well done![]()
Attached is my method for making PCB at home. May be it will be of assistance to those wanting to start making PCB at home.
The method uses the laser printer toner transfer with inkjet glossy photo paper as transfer media. I've been making PCB with 12mils tracks/clearance with 100% success.
Stupid questions make me smarter...
See how smart I've become at www.9w2bsr.com ;-P
What kind of glue do you use and which side goies down on the copper sheet, copy paper or photopaper?
How does the image get on the copper?
As you guessed it I'm a newbie in this area.
Hager
Very nice how to. Can you tell me what paper you use?
I tried using kodak paper and it didn't work well at all. Had limited success with hp photo paper. Thanks.
1. Will this process work with an inkjet printer?
2. Can you give us more info on the paper required, and also a supplier.
Thanks,
Jerry
Thanks for the guide, nicely done.
Jerry, I've read elsewhere that it is the toner that transfers, so it needs to be a laser printer or copy machine.
Just to clarify... You make a print of the circuit on a full sheet of paper. You then locate over it (register) and glue down the leading edge of a piece of glossy inkjet photo paper. You then re-feed that composite sheet through the printer which gives you the circuit printed on the photo paper. You then heat transfer...etc.Originally Posted by abasir
Is this correct?
Chris
The ones i just made i didn't glue anything. I used a photo copier. So i just used the photo paper and printed my board design directly to it. Seems to have worked. I cleaned the copper board. Dried it then put the photo paper on the board and used an iron. The paper itself stuck right to the board. I haven't cleaned it up totally yet. But it seems to have worked.
Any glue will do (I'm using double sided tape). Print on normal paper first, then glue the photopaper (glossy side up) over the image AND print the artwork again. Remove the photopaper, place the printed side onto the copper and proceed with ironing.Originally Posted by Mr.Chips
I'm using EPSON Glossy Photo Paper (120gm) meant for 1440dpi printing.Originally Posted by TinkerDJ
What is the problem?
If toner is not sticking, increase heat and iron slightly longer.
If toner expands (your tracks gets wider) then the iron is too hot.
Apply good pressure when ironing.
This process WILL NOT work with inkjet printer. The laserprinter or copier toner is made from plastic. Upon heating, it'll melt and sticks to the copper and act as etch resist during etching.Originally Posted by CJL5585
Paper as above reply.
YES... I'll update the guide later incorporating the Q&A here...Originally Posted by OCNC
