Old 01-10-2005, 10:24 PM
ccm ccm is offline
ccm is on a distinguished road
Clarification needed on current limiting resistors
I've done all the math and understand the wattage & ohm ratings of what I'm going to need and require for my particular senario... but the doc's I have with my board, and what I've read and seen online suggest that the current limting resistor should go on the + pwr legs for each stepper. I would think that you'd want to have the current limited at the feed to the board to reduce the excess current, so it doesn't cause uneccessary heat. Am I way off base here ? or has anyone else thought along these lines ?
Then again it could just be a case of extreme dislexia, and that's how I should have had them configured to begin with..... duh...
thoughts, suggestions ?
thanks guys,
Arthur
Old 01-11-2005, 09:16 AM
ViperTX is on a distinguished road
thanks guys,
Arthur
Arthur, it a circuit...so as long as the resistor is in the circuit it will do it's job.
Calculating current limiting resistors (I need serious help) Konstantin General Electronics Discussion 13 07-25-2005 04:10 PM
Current limiting resistor pyrojon General Electronics Discussion 8 04-19-2005 08:47 PM
Motor calculations jevs General Electronics Discussion 25 03-21-2005 01:05 PM
Clarification Needed - (warning Noobie content ) ccm General Electronics Discussion 1 11-09-2004 11:35 AM
Current limiting on homemade driver MrBean General Electronics Discussion 8 10-22-2003 03:02 PM
