I have a Porter Cable 3 1/4 HP single speed router that I'm having trouble finding an affordable VFD for. The 15 amp rating is more than most 115 volt VFDs can handle. Can Porter Cable 115 volt routers be rewired for 230 volt operation? John |
| Usually it will have that information in the terminal box, The amount of terminations usually indicate it also. I am assuming this is a 3 phase unit? Al.
| The router is a single phase Porter Cable. I thought someone may know if the 230 volt European routers are the same unit with the field windings wired in series, while the 115 volt units have the field windings wired in parallel. John |
| It most likely is a Universal series motor, the field will already be in series with the armature. The are made for either 120 or 240, the only thing you can use to vary speed is a Triac style speed control, the torque will drop with rpm though. Al_The_Man I have to use this pseudonym as somehow my user name has been blocked on any computer for some reason. I am trying to resolve it. |
| Thanks for the replies. I did find one at cnc4pc.com. It can be controlled directly from Mach. The only problem is the amp rating is the same as my router motor. I would feel a lot better if the VFD had a few extra amps as a safety margin. John |
| 120 Volts? | BrendaEM | Industrial Hobbies (Support forum) | 11 | 04-08-2008 08:24 PM |
| Rewiring BOSS for single phase | jderou | Bridgeport and Hardinge Mills | 37 | 10-27-2006 09:49 AM |
| 5 volts to 1.5 volts? | ZipSnipe | General Electronics Discussion | 5 | 08-18-2006 05:18 AM |
| Boosting three-phase 240 Volts to 480 Volts | Old Car Guy | Phase Converters and VFD | 6 | 05-01-2006 09:27 AM |
| I need english instructions for rewiring hp 7475..please help | drama | Printing, Scanners, Vinyl cutting and Plotters | 1 | 04-24-2006 10:18 AM |
