please see the attached image. it's stepper driver board: 2xL298 (parallel), with diodes and sense resistors, capacitor & connector. at first I made the small one, it work well (the yellow line is correction -> i forget to connect common ground) the problem is the space is to tight for L298's heatsink and big diodes. then I make it bigger, and the problem come...the motor now have noisy sound. color on layout: green = ground red = vss (24v) pink = vcc (5v) blue = L298 output for bipolar stepper where are the mistakes? |
| i re-check the circuit, the pink(vcc) and the green(gnd) are not shorted. if it's shorted, the circuit will not work. both layouts work, but the bigger layout causing my stepper motor having noisy sound. both layouts use the same component, except diodes. small layout use BYV27-100 big layout use UF5404 (I have tried to replace it with BYT-56M but still noisy) btw, i replaced BYV27 diodes because it's IF.av is 2amp...can it handle 3amp? i have tried operating the BYV27 with 3amp current, but i'm affraid it will getting hot and break |
| vtxstar, the problem is solved. at first i thougt that the problem came from this board or layout. but the problem is on the other board (my L297 & L298 are not on the same board). on my other board (which contain L297), I forgot to put rc filter on sense line, that's why the noise appear. |
| PDF Layout | alien_X | Rockcliff Machine | 2 | 01-06-2009 05:10 PM |
| Help with PCB layout | tajord | General Electronics Discussion | 0 | 05-30-2008 01:16 PM |
| How do i layout an assembly? | genexis | Solidworks | 1 | 06-22-2007 09:44 AM |
| Layout Dye | mjarus | General Metalwork Discussion | 5 | 12-30-2005 11:06 PM |
