Old 03-31-2009, 09:39 PM
parametric.ms is on a distinguished road
DIY Adjustable DC Power Supply 0-100VDC / 1A
I would like to build Adjustable DC Power Supply 0 - 100V DC / 1A to control my Magnetic Chuck on Surface Grinder.
Anyone can help to make my dream come true?
Regards,
Andre
Old 03-31-2009, 09:43 PM
Al_The_Man's Avatar
Should be very simple with 2 rectifiers and two SCR's, a POT and a few other components.
Google for full wave SCR control.
Old 03-31-2009, 09:58 PM
If you don't mind, just bring me through the site Al I'm not sure what I looking for
Old 03-31-2009, 10:02 PM
Al_The_Man's Avatar
I will see if I can find a schematic and post it.
Old 04-01-2009, 08:00 AM
vger's Avatar
vger is on a distinguished road
Andre, you may be able to use a DC varriable speed control. Here is one on ebay that should work for you. (not mine)
http://cgi.ebay.com/NEW-KB-KBIC-120-...3A1%7C294%3A50
Steve
Old 04-01-2009, 03:31 PM
Al_The_Man's Avatar
This should work at not much cost, an off switch could control the relay, contacts only are shown.
Old 04-01-2009, 10:46 PM
Al, I see your attach. What is specification for Toroidal transformer & Rectifier Bridge?
Old 04-02-2009, 09:02 AM
johnmac's Avatar
johnmac is on a distinguished road
Another option would be an autotransformer and a rectifier.
John
Old 04-02-2009, 09:06 AM
Al_The_Man's Avatar
The bridge can be any off the shelf item rated for 200~250v at the current you want to supply, the price difference is very little for higher rated versions.
The toroid can be any ferrite ring type found in PC power supplies etc, just wind one layer of around 18g on half in one direction, half in the other.
The Triac and Diac are older part numbers but they should cross over to current numbers, and they are not that critical for this application.
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
Power Supply help dirtdiggler Viper Servo drives 44 05-08-2009 11:00 PM
100VDC 12 Amp SSR's Santa Fe Al General Electronics Discussion 5 10-03-2008 10:58 AM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
