Old 03-29-2009, 03:56 PM
omarfarrar is on a distinguished road
motors requiring different voltages on same controller
I have a controller with G320's and a 55 vdc power supply that drives servos on a large machine. I would like to be able to share the same controller with a smaller machine with servos wanting only 36 volts. I suppose I could swap power supplies to motors as necessary, but I am wondering if there is a way to use the 55 volt power supply in both cases but limit the voltage to 36 volts when using the controller on the smaller machine. Also, in some cases I may want to use 55 volt motors and 36 volt motors on the same machine, so I'd really like to control the voltage going to each axis.
Old 03-29-2009, 04:14 PM
Al_The_Man's Avatar
I am not sure what the recommendation is for the drives you have, but the AMC drives I use they recommend a PS to be from 10% to 50 % higher than the rated motor voltage.
And mention that higher voltage is nor normally a problem.
http://www.a-m-c.com/content/support...ml#selection03
Enable voltages on M1 pin 1 dodgy74 CncBrain 6 01-04-2010 03:35 PM
This Motors + This Speed controller? JMcDonald Benchtop Machines 12 09-30-2007 10:46 PM
Combining servo motors that have differing voltages ~ Question RotorRouter Servo Motors and Drives 2 08-18-2005 07:08 PM
need new motors and controller DAB_Design General Electronics Discussion 4 09-08-2004 09:57 AM
Wish controller and step motors should I use.... Mikael General Electronics Discussion 4 06-30-2004 04:35 PM
