I'm building stepper driver using L297+L6203. since the snubber circuit on L6203 datasheet seem not operate very well, I need to redesign it. I found an application note with snubber formula. my stepper motor current rate is 3 amp. my power supply is 24volt. my chopper rate is 25880 Hz (~26 Khz) 1st equation: (done) Rmax = Vs min / I peak = 22.5 / 3 = 7.5 ohm 2nd equation: C = I peak * dt/dv --> how to determine my dt & dv ??? 3rd equation: Pd = (I1 * I1 * R * DC) + (I2 * I2 * R * DC) I1 = current at turn on I2 = current at turn off R = snubber resistor (7.5 ohm) DC = duty cycle of current flow how can i determine I1, I2 and DC ??? |
| Hi, Snubber bible is here : http://www.cde.com/tech/design.pdf http://www.cde.com/catalogs/igbtAPPguide.pdf The most important is to use MICA or POLYPROPYLENE capacitors forget ceramic or tantalum. Have fun, MJLFR |
| Formula for calculating RPM? | SSfab | Mechanical Calculations/Engineering Design | 28 | 03-28-2012 09:18 AM |
| need help on snubber ciruit | xinzc28 | General Electronics Discussion | 3 | 12-29-2008 08:56 PM |
| Calculating torque | jakovn | Linear and Rotary Motion | 8 | 11-07-2008 10:13 AM |
| Need help on calculating steps | rustamd | Mach Software (ArtSoft software) | 17 | 08-03-2007 07:08 AM |
| Help calculating power please? | Oldmanandhistoy | General Electronics Discussion | 20 | 05-30-2007 10:00 AM |
