I've seen this equation posted several times C~(80000*I)/Vdc. Were was it derived from? I was looking through my electronics devices book and I was trying to work backwards starting with the ripple factor equation - eq: r=Vr/Vdc(100) Vr = rms ripple voltage Vdc = filtered dc output voltage I was working backwards with 2.5 % ripple and 5 % ripple (What is a common % ripple to use?) following eq: Vr = [0.0024(Vdc)]/(Rl)(C) Rl = Load Resistance C = Capacitance of Filter capcitor You see, I am finding it hard to work backwards not knowing what Vdc is or Vr. Any suggestions?? I'm looking at putting these two toroid transformers in parallel... EBAY: You are bidding on 2 new 800VA toroidal transformers. They are precisely made for high-end power amp or servo amp. They have very low power loss and magnetic leak. Labeled input 115 / 230 VAC 50/60 Hz (single coil with center tap) and outputs 40VAC x 2 (dual coils) and 15V x 2(Dual coils). 1. Primary I = 0.03A, Secondary V = 46.2VAC at 0.0A 2. Primary I = 1.75A, Secondary V = 45.3VAC at 4.5A 3. Primary I = 3.41A, Secondary V = 44.5VAC at 8.9A 4. Primary I = 5.02A, Secondary V = 42.9VAC at 12.9A 5. Primary I = 6.76A, Secondary V = 41.6VAC at 16.6A I plan on hooking the two 40VAC from each transformer in parallel through one bridge rectifier and unwinding the two 15Vac to 4.5 Vac to use as 5v supply and run it through a separate bridge rectifier. I need help determining the size of the capacitor for the 40Vac (55.15 Vdc after rectification) and for the 4.5Vac (~5 Vdc after rectification) I've gotten confused about determining the current from this figure 800VA - is it I = 800VA/Vac or 800VA/Vdc? I think the total current would come out to ~30amps Using this formula C=(80,000*I)/Vdc I get: 55.16Vdc : C = 43,509 uF 5Vdc: C = 480,000 uF ???? $$$$ Any suggestions...Please |
Al
| I found this site helpfull aswell as all the wonder information I got from the members on this site. http://hyperphysics.phy-astr.gsu.edu...con.html#emcon |
| Calculating acceleration rates | mcmmach | General CNC (Mill and Lathe) Control Software (NC) | 4 | 07-26-2010 07:55 AM |
| Calculating gear ratios? | CNCadmin | Mechanical Calculations/Engineering Design | 12 | 06-21-2008 06:22 PM |
| Calculating current limiting resistors (I need serious help) | Konstantin | General Electronics Discussion | 13 | 07-25-2005 04:10 PM |
| Need Source for Cheap PS Filter Capacitors? | Bird_E | General Electronics Discussion | 2 | 02-08-2005 12:29 PM |
| How measure resitance, voltage, current, and capacitance. | ynneb | DIY-CNC Router Table Machines | 0 | 04-27-2004 10:03 PM |
