Old 03-20-2009, 03:58 PM
dar303 is on a distinguished road
Driver for 3-phase high speed spindle?
I managed to aquire a GMN 60.000 rpm spindle from a scrapped PCB-drilling machine. They threw away the drivers and electronics so I need to find a new driver.
This is printed on the spindle:
GMN TSS 62 - 60000
0,7kW S 6-60%
60000 1/min
165V 3,8A 1000Hz
I found a pdf with information on the newer spindles from that company so I have some clues.
There is one ground wire and three wires with bigger diameter that I assume is U, V & W (three phase) and two smaller that I gather is a temperature sensor. I will measure and see but I don't think it is a tachometer since that seems to be an option only used for GMN spindles that have hollow shaft cooling.
What kind of driver could I use to power this spindle, a servo driver of some sort (in open loop mode so to speak) or some kind of VFD? What about the 1000Hz figure, most VFD:s I have seen goes to 400Hz.
Economy is a factor, I need something relatively cheap since this is for a hobby project. The spindle cost med about 250usd and I need an air compressor and a air/oil lubrication system...but it is a nice challenge to try and get it going!
Any tips are appreciated!
/Daniel, Sweden
Old 03-20-2009, 07:38 PM
One of Many is on a distinguished road
Danfoss VLT2800
Inverter drive
Another spindle drive
Just Google up 1000hz spindle?
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 03-21-2009, 07:04 AM
Thanks for the tips!
Those drives looks expensive, I'll look around and see if I can find any second hand ones on Ebay.
I guess there isn't any hobby-level motorcontroller that can be used, this is a pretty specialized application!
Edit: I found this thread on the forum: http://www.cnczone.com/forums/showthread.php?t=41699
Add DIY high speed spindle? bseibenick General Metal Working Machines 11 12-08-2009 09:35 AM
High speed air spindle pebbert General Metalwork Discussion 3 11-08-2008 02:25 PM
My new High Speed Spindle Jay C Benchtop Machines 19 10-26-2008 09:24 AM
High speed spindle yngndrw General Metalwork Discussion 9 06-26-2008 03:19 PM
High speed spindle... how high? jonesja2 General Metal Working Machines 0 06-04-2007 07:18 PM
