Hello, I have recently developed a new problem where my stepper motor will reverse for no reason while executing my G code. I am running EMC and the screen shows that the motors are operating correctly, but really the motors are not. This is happening on only one axis. What could create this type of problem? Any help is greatly appreciated. Thank you, Brian |
| Possibly intermittently loosing your Dir pulse on that axis? Al.
| Hey Al, Yeah, I was kind of thinking the same thing. Does the dir signal high for one direction and low for the other or does it accept a sequence? It appears that the wires are secure. I'll double check my parallel port cable, I hope its not a faulty board. Thank you, Brian |
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| Hello again, I checked the wires and they are all hooked up properly. I checked the signal, and it coincides with the direction indicated in the G code. So no problem there. I can almost make the motor change directions on command by pressing the axis in that direction. If i put resistance on the router, it will reverse the direction. And I can do the same thing to make it go back the other way. What are the chances something is wrong with my board (L297/298)? What else could I test? Thank you, Brian |
| My parallel cable is "shielded" but all of my jumper cables from board to board in addition to my motor cables are not shielded. If this is the problem, would the shielded cables be preventing outside environment interferences or other interferences produced from signals on the board? Is there a simple way of testing this theory, or do I just have to replace the cables and give it a try. Thank you for your input. |
| Hi buz0340 The most interference will come from the spindle motor then your steppers does it do this with the spindle running or just with the steppers moving/engaged If you do put shielded wires on your motors make sure you only ground the input end of the shield You really want to use shielded wires were ever you can
__________________ Mactec54 |
| Hi again, This happens when the spindle is not running. I also isolated the board with the problem by disconnecting the power to the other two as well as the step/dir signals. I still had the problem. I am beginning to believe shielded cables will not help. If you have any other comments I would love to hear them. thanks brian |
#12
| I had something like that happen to me before. Although my drives don't use the L297/298 combination, if I recall they still use sensing resistors. Anyway turned out that one of the sensing resistors was not soldered and only making intermittent connection. I would suspect that half of the drive output is weak for some reason. Do you have a scope? Jon |
| M01 command | slideleft | Haas Mills | 4 | 11-20-2008 03:01 PM |
| G03 COMMAND HELP!! | hkfanatic | G-Code Programing | 25 | 08-04-2008 03:14 PM |
| tolerances for 3d command | moldmker | BobCad-Cam | 4 | 10-07-2007 04:17 PM |
| what is the same command? | hop | G-Code Programing | 0 | 06-20-2006 05:24 AM |
| fanuc servo motor moving without command | mtech | General Metal Working Machines | 5 | 06-16-2003 08:39 PM |
