Hi I was hoping some one would help me figure out this power supply problem I cant find my documentation that I know I once had and most likley still do some where on this computer I would like to install some fuses and some leds so i know what is going on I seem to remember the leds connecting to the fuses on one end somehow but it was some time ago I have uploaded some pictures here http://www2.whidbey.com/ror/power%20supply.html please have a look at the parts that blew and what I am thinking of doing about it any comments about if there is a better way or what have you feel free to let me know |
| Woke up in middle of the night 3 am The only way that makes sense to me is On the positive side after the fuse the resistor connects then the positive side of the led then a wire to the negative side before the connector Does this sound right ? Well back to bed |
| It look like there is more than one unit, I would reverse engineer one and use it to repair the blown one, you need to draw out the schematic. It is almost impossible to tell anything from the photo's except general layout. Al.
| Its pretty simple. You overloaded the board and the trace (not sure which) from the bridge rectifier to the screw terminal blew out. If there was a sustained short it may have caused the trace to heat up and pop. In any case, fuses are necessary as you now know. Chances are that a fuse would have blown before the trace on the board. There was nothing else so the trace acted like the fuse. I would check to make sure that the load on the power supply is not larger than it is rated. If you are stalling your motor with a G320 you might be trying to pull 20A out of a supply that looks about like 10A or so. Short term (like acceleration) the components can handle the overload. When the overload continues, the components start to fail. Matt |
| Thanks the stalling was a mechanical problem with the gear reduction that has been fixed I replaced all the rectifiers with 35 amp units I have seen a guy run a full size milling machine on one of these power supply’s with the same motors I can use the fuse module he sells but would have to build a way to see inside the case and now it sits under the machine with just the plug in side visible Truthfully I have no where else to put it Currently I have to pull it out from the other side and open it if there is a problem I have contacted the manufacturer to see if he would sell me some of his leds and resistors he has not replied yet or if he would tell me where or what to get I am reading the resistors as 23 Ohms and am having trouble finding them they look like 1 watt ? I am on page 8 of a huge electronics book but went back to read page 2 again So it seems to me my best bet is to cannibalize a couple of his fuse modules of his and I have a couple the wires will be real short but I should be able to desolder the resistors And leds and connect them with some wire Should have taken electronics in collage Instead of diesel heavy equipment mechanics Well with the parts I have I should be able to put something together to indicate what’s going on from the side I can see And I will start studying electronics in my spare time thank you for the replies |
| Ordinary Radio Shack LED's are fine for this. From your pictures, the resistors look like 10K 1/2 watt. The resistor values are somewhat dependent on the power supply voltage. LED's will usually light up with 1 or 2 milliAmps of current and tolerate up to 20 milliAmps, so there is a 10:1 range to work over. The formula for the resistor is: R = (PowerSupplVoltage - LEDVoltage) / LEDCurrent PowerSupplyVoltage = what your power supply puts out LEDVoltage = voltage across LED, 1.7V is usually a good value. LEDCurrent = the amount of current through the LED. 10 milliAmp or 0.010 is a good number. The wattage rating for the resistor is: P = (LEDCurrent^2) x R LED Current is the value you used in the formula above R is the value you calculated The power rating of the resistor must be larger than or equal to the value P, I usually get resistors 2X the calculated power. For example, with a 48 Volt power supply and 10mA of LED current: R = (48 - 1.7) / 0.010 = 4630 ohms, 4.7K is the next standard size. P = (0.010 ^ 2) x 4700 = .470 Watts. 1/2 watt is usable. If you want the LED to turn on when the fuse blows, connect the cathode of the LED to the end of the fuse that goes to the load, one end of the resistor to the annode of the LED and the other end of the resistor to the end of the fuse that the power supply is connected to. If you want the LED to be on if the fuse is good, connect the cathode of the LED to the minus side of the supply. Connect the annode of the LED to one end of the resistor. Connect the other end of the resistor to the load side of the fuse. Both of these explanations assume that the fuse is on the + power wire, which is generally where you want it. To tell the annode from the cathode of an LED, hold it with the wires facing you and look at the plastic at the base of the LED. There should be a small flat side on the plastic edge on the cathode side. It is sort of D shaped, but the flat is not that pronounced. Good Luck, Bob |
| thanks I think you saved me alot of trouble I will get this figured out when I get home from work tonight one question lets say I try experimenting with the setup some with this being on the power supply whats the best way to discharge the stored power or the best way to be safe before connecting the stuff if I have all ready ran it with another setup normally I just wait a few hours but some times this is not convenient how do you guys go about this thanks |
| Usually the quick way is to use a large wattage incandescent lamp, it possesses a very low resistance when cold that will rapidly dissipate stored DC and you can also see the decay visually. Al.
| wow thanks so much for the information I have already used the formula once to figure out the resistors for the leds I have As i live on a island and the radio shack here only has 2 of each led they carry and said it would take some time if I order from them then I called them and they did not have the resistors so since I have to order the resistors I am ordering some panel mount leds with wires attached here is how new I am at this the place I am ordering from had about 15 types of resistors and it took me a wile to figure out I wanted to be on the carbon film resistor ordering page well soon as I use the formula again with the specs from the new leds I will know what resistors to get thanks again for making it easy enough for me to understand I will try to learn more about this stuff it seems a little more fun now and thanks for the light suggestion sounds like a great idea I will go make me a new tool with a light socket and some clips to add to my collection Last edited by eat; 03-18-2009 at 07:49 PM. Reason: want to add a little more |
#10
the new parts seem to work great the led lit up and was working for a wile after the new parts blew out I believe the resistor and led parts and fuses will be fine you can see in the pictures below when I tested the first one after I got it soldered to make sure it worked before soldering the others but the bad news seems to be that the lack of fusses was not the problem soon as I flipped the breaker the 2 rectifiers in the same place as the ones before blew out I have them circled in blue I think they where overloaded like matt said but it must be from something on the toroid side of the rectifiers all i did when i got these was connedct the wires per instructions to run as 240 that will be one of the first places I check then I will check whatever elce I can get a look at to see if I can see or smell out any problems they both blew out right by where the green wires enter the rectifiers i did run this for about 3 hours in the last few months with no problems untill the sudden blow out the first time if I cant find anything I may test them seprately I have included some pictures if anyone would like some others of certian areas let me know it looks a little funny as I had to put it part way under for the cord to reach Last edited by eat; 03-29-2009 at 04:42 PM. Reason: makes more sense |
#11
| I have not been able to find ant thing wrong so far the power coming in checks out the onley thing the 2 rectifiers have in common is the ground and both of them have the green and blue wire reversed from the other 2 that is how they have always been any one have a idea of what I should be looking for if I test the blue and green wire on one of the parts that blew AN15452 1500 watt this is the part number on the 2 units I will try to track down some more info I guess I will try to run some tests now |
#12
| well I disconnected one of the blown rectifiers and connected a voltage tester thinking that would give me a good reading of what it was getting when it blew turned on the power and it blew the other 2 rectifiers at the blue wires so i figured that was about all the work on it I could afford for now and decided to call it a night |
| Tags |
| fuse, led, power supply, rectifier |
| How'd you supply your power supply? | cnczane | DIY-CNC Router Table Machines | 12 | 08-28-2011 05:13 AM |
| parts for my power supply | eloid | General Electronics Discussion | 0 | 03-07-2008 09:02 PM |
| Power supply parts | Tasos_Eco | CNC Wood Router Project Log | 2 | 09-19-2007 03:31 PM |
| More power from switching power supply | R.thayer | General Electronics Discussion | 4 | 03-10-2007 07:03 PM |
| Power Supply from a computer power supply | jmytyk | General Electronics Discussion | 21 | 01-11-2006 02:56 PM |
