Results 1 to 3 of 3
Thread: stepper motors turn off
    Apr 2008
    Question stepper motors turn off
    Howdy, I am having a problem with my stepper motors. When I turn on my power supply and then turn on my computer the motors get power to them. However as the computer boots up the motors loose all power. The only reason I can think this is happening is because I run my driver board power from a usb power (5v) and the usb somehow resets as the computer loads (????). Should I be running the boards 5 volt power from a separate supply?
    Dec 2004
    Quote Originally Posted by gaffa View Post
    Not for anything, but you should be booting the computer first, and then powering your drives for safetys sake. This would also prevent the usb from reseting your drives if that is the problem.
    Registered neilw20's Avatar
    Jun 2007
    The standard.
    Look www.usb.org and read the standard.
    The power available, may not be as expected, and when expected.
    In certain cases laptops, for example may turn off the USB power when a lack complex communications have deemed that the power should be off.
    Short of a properly designed interface, power may be unreliable, depending on the computer and BIOS design.
    Buy a plugpack and you will never have the problem.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  1. Cannot get my motors to turn
    By Danno in forum Mach Mill
    Last Post: 11-19-2009, 09:10 PM
  2. how turn stepper motors off when not in use in Mach 3?
    By uplb in forum Mach Software (ArtSoft software)
    Last Post: 01-01-2009, 09:24 AM
  3. stepper motors turn only one direction
    By Mike Boarman in forum General Electronics Discussion
    Last Post: 11-24-2006, 05:43 PM
  4. I Cant Get my motors to turn
    By bigbigjimb in forum General Electronics Discussion
    Last Post: 10-24-2005, 11:14 AM
  5. Motors wont turn
    By moto21 in forum Mach Software (ArtSoft software)
    Last Post: 09-22-2005, 11:13 AM
