Old 03-13-2009, 09:19 PM
ged ged is offline
ged is on a distinguished road
solenoid valve for atc
Can anyone tell me if I can use a 12 volt 3 way 2 position single solenoid valve to operate a spring return air cylinder for an auto tool changer (following the great "Hoss" instructions)Or do I have to use 110 volt? I have a Mini IO bob with Vampires.And what solid state relay do I need?
Any help would be greatly appreciated GED
Old 03-13-2009, 10:33 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi ged!
Why not just use THIS one?
http://surpluscenter.com/item.asp?UI...00&catname=air
CR.
Old 03-14-2009, 10:55 AM
Whoops! Forgot the relay:
http://www.surpluscenter.com/item.as...tname=electric
CR.
Old 03-14-2009, 05:11 PM
ged ged is offline
12 volt solenoid
Thanks CR
I ve already purchased the Bimba air cyl (4 bucks) and the EMC VC82,3 way,2 position 12 v dc solenoid from Princess Auto and I was just hoping I could still use it if I used a 12 volt ac adapter or other 12 volt supply.
Old 03-14-2009, 05:16 PM
Originally Posted by ged View Post
Thanks CR
Sure, if you already have it, why not? As long as it turns the air on and off. But the DC relay only handles AC, so you will have to relay your primary 120AC Voltage to the 12V PSU.
Seems overly complex to me. I would just buy the 120V solonoid and have fewer connections to fail.
CR.
Old 03-14-2009, 05:30 PM
ged ged is offline
solenoid
Thanks for your help CR I think Ill take this one back and get the right one
Tire Valve / Shraeder Valve Dimensions jamiedaugherty Mechanical Calculations/Engineering Design 19 01-22-2010 09:46 AM
Problem- Solenoid jorgehrr Servo Motors and Drives 2 08-04-2008 11:22 AM
series II interact II 24vdc solenoid valve bigtoad170 Bridgeport and Hardinge Mills 0 12-13-2007 02:17 PM
Oxygen Pierce solenoid Valve roady89 CNC Plasma and Waterjet Machines 11 10-05-2007 05:11 PM
solenoid help jimini Printing, Scanners, Vinyl cutting and Plotters 2 02-13-2007 12:15 AM
