| ahh i see.When ever i think im getting better at electronics i always get to show my ignorance haha I should have knowed because i have used thermistor befor but they were very small but i never used them in this way. This will work out nice for future projects:P thanks unterhaus for the heads up ![]() http://www.mouser.com/catalog/620/374.pdf you know after you start adding up the parts. 4 for the bridge, 2 for the thermistor 10+- board, wire clamps, resistor (10-15 hour or so of time to build it?) not really to bad of a deal for 30 bucks for people who dont have parts laying around. :P Last edited by sendkeys; 12-23-2004 at 11:44 AM. |
It's hard to remember that thermistors are used as sensors and for inrush. At work, the thermometers are little electronic things with thermistors in them. At Christmas, they turn the heat down to 55F by computer. One of the guys wanted to work on his thesis, but they wouldn't turn up the heat just for him -- they only do that for lab animals or if you can prove your experiment needs higher temperatures. We were going to modify the thermistor circuit so we could adjust the resistance, but he came up with an easier plan and hung a bag of snow on the thermostat. The modification would have been useful though, they are really bad about setting the temperature, and there is a very limited range that you can set the temp yourself. |
| If you mean capacitor charging inrush (not sure you do), then a thermister solution might not be the ideal way forward (too much resistance all the time, too slow to react, etc). I'd think a current limiter is more the way forward. (Easy enough to make with a mosfet and a bit of analog control circuitry, doesn't need to be 0.001%). |
| > Add series resistor to PS AC line and remove (bypass) by relay after 1sec. It's a good and simple idea, the problem is keeping everything in the correct state when dealing with power on/off transients (eg machine powered up for half a second, then turned quickly off and on). This may or may not be important to your application. |
#11
The inrush current limiter allows the caps to charge at a slower more relaxed rate, giving the transformers flux time to stabilise and reducing the high initial current draw to a less fuse blowing, light dimming level and reducing the stress on your power supply componants. Should help them last a little longer. Some good circuits for this can be found here. http://sound.westhost.com/project39.htm Last edited by GrahamIT; 11-11-2005 at 12:15 PM. |
| RFQ two Aluminum parts, cheap no rush | mike_r | Employment Opportunity | 0 | 04-28-2005 10:14 PM |
