Old 12-21-2004, 08:25 PM
cnc2k is on a distinguished road
OMS driver wiring help.
Hello everone,
can anyone confirm is my wiring is right or not.
[IMG]www.xizou.com/images/driver.jpg[/IMG]
Old 12-21-2004, 11:53 PM
Zippi is on a distinguished road
Without knowing the driver chip, looks fine to me!
Old 12-22-2004, 02:08 PM
Gold Member
Mariss Freimanis is on a distinguished road
cnc2K,
It looks OK to me but I would lose the zeners across the windings. I designed that drive; it's big, black, heavy and full of epoxy right? It is the primative ancestor to the G201. The pin-out is the same.
Mariss
Old 12-25-2004, 12:10 AM
thanks for the reply, can you take closer look on pin 7-pin12 on this diagram. http://www.xizou.com/images/driver.JPG
also, what is pin7 use for?
Yes, the driver and black, bag, and with epoxy on the back.
thanks for you help.
Old 12-25-2004, 12:29 AM
Gold Member
Best bet is to download our G201 manual and wire the OMS drive per the G201 user's manual. Same pinout, same current set resistor values, same everything. Just a much older version of what we make now.
Mariss
Old 12-25-2004, 01:16 AM
for pin 7 i should connect it to ground or just leave it alone
Old 12-25-2004, 06:11 PM
How can i find out what size of resistor to use? i have 2 sets of stepper motor
1st set series 1.75amp and 2nd set series 3.3 amp?
i want to pull 5v out from my 24v power supply, i can use 5V Fixed-Voltage Regulator 7805? 5v is for 3 drivers.
Superior Electric PDM155 Driver Hookup vladdy General Electronics Discussion 2 07-16-2005 03:12 AM
Wiring of RS 232 Cable Niall Machine Problems, Solutions , Wireless DNC, serial port 6 03-23-2004 03:36 AM
Fun with floppy stepper and driver Konstantin General Electronics Discussion 5 03-08-2004 01:18 AM
Wiring a Gecko Driver board balsaman Gecko Drives 12 05-27-2003 03:20 PM
