Old 02-11-2009, 05:55 AM
eloid is on a distinguished road
estop
i need some help locating a good estop circuit, I would have cnc4pc c23 break out brd... Just dont know how wire up a external relay to kill all power
to motors but keep break outbrd runing ,,, this is my frist project i have never step up mach3 so im still learning as i go.
can some post a link or drawing, I like to kill power to the router also.
Old 02-11-2009, 06:39 PM
johnmac's Avatar
johnmac is on a distinguished road
You can wire the E-stop switch to a pin on the BOB and assign it as the E-stop in Mach. No relays needed.
John
Old 02-12-2009, 06:01 AM
I need the relay for the router, want to power on and off and kill power (e-stop), and would like have hardware estop more for for safty.
Old 02-12-2009, 07:28 AM
johnmac's Avatar
You can use a solid state relay for the router. It can be controlled directly from the BOB.
If you use the E-stop in the software, it will use the motors as electric brakes to stop the machine. If you kill the power, the machine will want to coast to a stop.
John
Old 02-12-2009, 08:02 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
You can wire this relay to provide power to router when steppers are powered:
http://www.surpluscenter.com/item.as...tname=electric
Estop will unpower steppers and allow relay to open, shutting down router.
CR.
Old 02-12-2009, 10:06 AM
contactirfu is on a distinguished road
Read this section below
http://www.mechmate.com/forums/forumdisplay.php?f=28
u have complete info here and also you can implement the e stop used here.
Old 02-12-2009, 11:40 AM
which link?
which link there so many
Old 02-15-2009, 02:15 PM
pause / resume after estop
so with estop relay, at no point do you ever want to break power to you bob.... just power to motors ie gecko drivers and router/ spindle
Never had any hands experance yet with mach but after resuming from a estop can u continue cutting? with out lost steps? if not is there a way to pause... and resume?
CR.
Old 02-15-2009, 08:23 PM
johnmac's Avatar
Just to clarify, the stepper drivers produce a high "step" current followed by a lower "hold" current. This lower "hold" current holds the motor to prevent the axis from moving when it shouldn't.
Now, when you hit the pause or stop in Mach, it allows the line of g-code in progress to complete before the machine stops. If you hit the E-stop switch connected to Mach, it will immediately stop sending the "step" pulses to the driver. The "hold" current will continue, working as a brake.
If you use a switch or relay to kill the power to the drivers, the motors will coast to a stop.
Either method can be used, it's up to you which to use.
John
estop diagram markus_detroy DIY-CNC Router Table Machines 6 05-14-2008 11:00 AM
Estop and limits krymis General Electronics Discussion 1 02-18-2008 05:39 PM
random estop erase42 DeskCNC Controller Board 21 02-02-2007 05:28 PM
ESTOP keeps happening klick0 LinuxCNC (formerly EMC2) 2 12-17-2005 11:06 AM
Estop HuFlungDung CamSoft Products 5 03-06-2004 01:24 PM
