Old 02-06-2009, 04:42 PM
ZipSnipe is on a distinguished road
Capacitor for my 9x20 lathe?
I have an older 9x20 lathe. The other nite the motor started making some freakish noises and blew my breaker. Took everything apart, opened the motor and one of the wire nuts had melted. Re wrapped with some electrical tape and hooked it back up only to have the same thing happen again. The motor(1/2 hp) spins freely and I suspect(hope) its the cap going bad.
My question is Grizzly only sells a 60 MFD 250VAC cap mine is a 40MFD 250 VAC. Can I use the 60mfd?
Old 02-06-2009, 05:48 PM
Al_The_Man's Avatar
Have you tried any local motor winding companies?
It could be the centrifugal start winding switch gone, if so a cap will not help.
Old 02-06-2009, 06:41 PM
Yeah I think I'll give a local one on Monday a shot! Thanx
9x20 Lathe Conversion dareposte Mini Lathe 71 11-16-2011 03:34 PM
Will this control RPM on a HF 9x20 lathe? seanreit General Metalwork Discussion 4 01-06-2009 01:22 PM
Cheap 9x20 lathe cnczoner General Metal Working Machines 0 09-26-2008 08:50 PM
9X20 Lathe chattering problems ccm General Metalwork Discussion 14 10-22-2005 12:55 PM
9x20 Lathe question ccm General Metal Working Machines 13 09-25-2003 05:52 PM
