Old 01-24-2009, 12:22 PM
Wanna be
Hack is on a distinguished road
Wiring home and limit switches
I am converting a RF31 mill to cnc capabilities and need some help wiring home and limit switches to a CNC4PC C10 breakout board.
I am really only starting with limit switches on both the x and y axis and want them to work as both limit and home switches. I have seen the option of using a limit as home. I will be controlling this with turbocnc.
How do I wire this to the board? I have pins 10,11,12,13 and 15 all available on the BOB. what ones should I use? Should i wire in series or parralel?
I would greatly appreciate some guidance here.
Thank you.
Dan
Check out what I am working on at www.routerbitz.com!
Old 01-24-2009, 01:22 PM
jalessi's Avatar
jalessi is on a distinguished road
I would be happy to help do you have a instant messenger?
Old 01-24-2009, 01:44 PM
ger21's Avatar
I'm not sure if TurboCNC allows you to use a single switch as both a home and a limit switch. I haven't played with it in a very long time, though.
Old 01-24-2009, 01:57 PM
jalessi's Avatar
Smile
Dan,
Here is a basic limit home switch wiring diagram for TurboCNC.
Jeff...
Old 01-24-2009, 02:03 PM
Al_The_Man's Avatar
Any reason why OR'd N.O. switches used instead of the more common N.C. switches in series for E-stop?
Old 01-24-2009, 03:25 PM
Bubba's Avatar
Bubba is on a distinguished road
Turbocnc WILL work with "Home as Limit".
In my case, I use NC switches for all axis. One pin to each axis. X=10, Y=12, and Z=13.
Now for the important thing. DO NOT SET UP LIMIT SWITCHES! Set Home is limit under the General Configuration screen.. by placing an X in the [ ]. I personally have set the home rate to 20 ipm but this was done after testing of my particular switches to see what worked best.
NOW, to keep your hair and I say this based on experience. Set up ONLY one axis at a time and get it working properly before you go to the next one. If you don't, I can almost guarantee you will be back saying it won't work! Been there done that.
Ok, you set it up lets say the X axis first. place the table in the middle of the travel and issue the home command G28 and the X axis should start moving in the proper direction. Using your finger, trip and HOLD the limit/home switch for the X axis and the table should stop and start moving in the other direction. If it doesn't, something is wrong. When you release the switch, the table should stop and the dro indicate the setting you programed into the ini file.
Don't forget that anytime you make a change to the ini file, you have to reset the prots before the change will take place.
Art
Old 01-24-2009, 03:27 PM
jalessi's Avatar
Thumbs up
Dan,
The Estop should be a normally closed, Al is correct.
Jeff...
Old 01-24-2009, 03:47 PM
Wanna be
Thank you
I will give some of this a try. I am not making th connections to the machine yet, Just wiring the box. Doing it in the warmth and confort of my home office instead of out in the 14 degree shop today.
Thanks again.
Wiring Diagram for Generic Breakout board, home and Limit Switches, Generic Drives. CJL5585 Open Source CNC Machine Designs 33 02-24-2010 03:39 PM
Wiring IH limit switches Shepard Industrial Hobbies (Support forum) 10 03-20-2007 08:28 PM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
