Old 11-28-2004, 07:15 PM
scott m's Avatar
scott m is on a distinguished road
expanding lpt port
Is it possible to expand the parallel port on old hp computer so that there are more pins available to do stuff with? I am just starting to mess around with this stuff and have blown out 2 pins on the port (no real worry, only $30.00 computer) so I would like to add something. I think I read somewhere about adding a whole port/output but am unsure. Any help appreciated. Scott. I already posted this before it occured to me it may be the wrong forum. I am running steppers with it though . New to cnczone.
Old 11-28-2004, 07:31 PM
ViperTX is on a distinguished road
You should be able to add an ISA card with 2 additional parallel ports...check that they are bidirectional...some code that I've seen uses this feature.
Old 11-28-2004, 11:29 PM
scott m's Avatar
Well thanks for the pointer in the right direction. I'd have replied sooner but I had to track down my own post, it seems to have happy feet . I am using C++ and I suppose I could access this address with it. Is that the limit on how many ports I could use?
Old 11-29-2004, 12:01 PM
The port limitation is more a Microsoft limitation then anything else. You could write a separate port driver routine to use additional ports.
Old 11-29-2004, 12:21 PM
Al_The_Man's Avatar
Here is a PDF on programming the parallel port in C and covers details.
Al
Old 11-30-2004, 07:33 PM
scott m's Avatar
Well thanks for helping me with this problem. It is fixed. Al, how on earth did you get all that into a 76kb pdf? I have never downloaded something so fast on my junk dial-up. IF I made a pdf with that many pages it would be about 4 mb . Some nice info in there too. I am relatively new to electronics so I imagine I will be posting a bunch of dumb questions from time to time. Scott.
Parallel Port Options JasonCroyle General Electronics Discussion 4 01-12-2005 07:23 AM
Output voltage on LPT port varies with OS on laptop? Beezer Computers and Networking 7 11-20-2004 03:12 PM
Have problems with G201 and printer port Christian Gecko Drives 2 09-26-2004 02:44 PM
Indexer LPT - HELP! CNC Pro General CAM Discussion 3 03-11-2004 02:20 PM
Using A Laptop Without Serial Port mtech Computers and Networking 6 08-17-2003 08:58 AM
