OK, wiring this relay http://cnc4pc.com/Tech_Docs/C15-DUAL...BOARD_Rev1.pdf to start and stop spindle via VFD, At the top of the drawing where it shows wires heading to the device, what happens to the ends of the wires where they end at the words "110/220 AC or a DC voltage"? I'm assuming that DEVICE in my case is the terminals of the VFD that accept the logic inputs. Do these "loose" ends get joined, and effectively the relay just opens and closes a loop from the board to the vfd, or is something else supposed to happen? Thanks! |
| I hope i understand your question. The V_IN is the terminal that is comon on the relay. As you can see there is a "NO" (meaning normally open) and a "NC" (meaning normally closed) So the outputs (NO and NC) would open and close depending on the state of the relay. The wires simply terminate under the screws. |
| The way I interpret this is the 110/220 AC or DC voltage is the SUPPLY for the device you want to turn on via the relay on the BOB. i.e. it is the AC or DC power supply feed. Al.
| Al, It could be used for a power circuit or for a logic circuit. Depends on how you want to incorporate the VFD. If it were me and i was wanting to start/stop a vfd with it i would try to use the logic circuit instead of powering it up and down.....but that's me |
| I have enough issues with BOB-used terminology as it is. ![]() Al. For the benefit of Endgrainguy , the contacts on the BOB would go to the Start input on the VFD. Delete the DEVICE on the drawing.
| TREE 310/325 Relay wiring diagram | ken fedirko | Tree | 3 | 02-10-2008 10:55 AM |
| Embarassing newb question | Spinnetti | General Metalwork Discussion | 5 | 01-04-2008 08:33 PM |
| solid state relay question | aegfurn | General Electronics Discussion | 9 | 02-23-2007 09:09 PM |
| Wiring a relay into my 3 phase motor | Bass_Player | General Electronics Discussion | 6 | 05-24-2005 09:50 AM |
| Relay question | shortbus | General Electronics Discussion | 3 | 04-26-2005 04:14 AM |
