Old 01-14-2009, 05:28 PM
m1ck is on a distinguished road
Twin Motors?
Hi all,
The machine that I have decided to build uses 4 stepper motors, 2 to drive the x-axis and 1 each for the other 2.
Can anyone tell me how I should connect the 2 that drive the x-axis? I will be using a Rockcliff 4-axis stepper motor driver which has a built in printer connector.
Thanks.
Mick.
Old 01-14-2009, 07:53 PM
Gold Member
Mariss Freimanis is on a distinguished road
Mike,
Use one drive per motor. For two motors driving the same mechanical axis, send STEP and DIRECTION to both drives from the same CNC controller axis.
Mariss
Old 01-15-2009, 02:36 PM
keebler303 is on a distinguished road
In mach3, and maybe others, you can slave axes together. So you would have 1 motor for x, 1 for y, 1 for z, and 1 for a. Then you would slave the a axis to the x axis in software. Then they will both move in harmony. I think this is better than pigtailing the step and direction wires (which I think is what Mariss is describing) because you can reverse the logic for the direction command so each motor turns in the opposite way, which will make your x axis move. You can also do this by switching the motor leads around but this is easier once everything is all hooked up.
Matt
Matt
Newbie- v twin 2 stroke gjs I.C. Engines 6 11-05-2009 08:20 AM
Twin Wobbler JOE65 Steam Engines 4 08-17-2008 11:40 AM
Another Twin balsaman I.C. Engines 28 01-10-2007 09:23 AM
new twin balsaman Steam Engines 6 05-02-2005 06:28 PM
another twin balsaman Steam Engines 8 11-08-2004 07:17 PM
