I have a geared motor that says it needs a starter relay and I have no idea what that is or if it's need please help. The motor is here http://www.surpluscenter.com/item.as...tname=electric It comes with a capacitor. I use regular relays in my building all the time but have no idea what a starter relay is. Here is a pic of the schematic on the motor. The motor is from surplus center so maybe that relay is just in the diagram from this motor being built for a specific application. Any help on how to wire this would be appreciated. Thanks. |
| I think I figured it out. The relay is what I thought. It allows the energy from the capcitor to start the motor then switches off the capcitor so just the line voltage is going to the motor. I'm bypassing the cap and the relay. I just plug it in and spin the shaft and it starts to run. I hope this doesn't hurt anything. It seems as though it can run in either direction based on which way I spin the shaft. I hope THIS doesn't hurt anything. I will continue to spin it in the direction the cap makes it go. |
| Your deduction about the start switch is correct, this motor does not have an internal centrifugle switch, which normally eliminates the external one. A split phase motor can be started by spinning the shaft and it will run in either direction as now the start winding/cap combination is not being used to give it the direction desired. There is high current flowing in the run winding when first switched on, so it is important for the motor to get up to speed ASAP after turn on. Al.
| If you choose that method, it is a bit easier on the motor if you can give it a hard spin a split second before hitting the switch. Al.
| Humming noise in Car Starter motor | ramee20374 | General Electronics Discussion | 0 | 10-25-2008 11:08 AM |
| Wiring a relay into my 3 phase motor | Bass_Player | General Electronics Discussion | 6 | 05-24-2005 09:50 AM |
| Relay question | shortbus | General Electronics Discussion | 3 | 04-26-2005 04:14 AM |
| How to set a relay for a spindle motor ON/OFF control | TTaki | TurboCNC | 2 | 03-09-2005 06:26 AM |
| Starter motor as servo? | wile_e | Servo Motors and Drives | 10 | 01-10-2005 05:57 PM |
