Old 01-05-2009, 06:07 PM
LaserImage is on a distinguished road
Countdown timers
This has really nothing to do with CNC but I thought I would ask here anyway. I am looking for a couple of inexpensive countdown timers for an ac outlet that can be set for 0-120 seconds and another that can be set for 1-30 minutes.
If I had the exact part list and some instructions I would be happy to build it but I don't have the experience or knowledge to try and figure it out on my own. I had thought of using the timer from an old microwave but even "repurposing" that might be beyond my skill level.
I need to keep them very inexpensive, less than $15-$20 if possible.
any help?
thanks!
Gary
Old 01-05-2009, 07:10 PM
Al_The_Man's Avatar
Look up 555 timers, you should find many, many. can be made for a few cents.
Old 01-05-2009, 08:28 PM
keebler303 is on a distinguished road
I'll second Al's suggestion and add that a good drive circuit would be a ULN2003 and a relay with a 5VDC coil. This will take the 5V signal from the 555 timer and control a relay for a 110VAC outlet.
Matt
Old 01-06-2009, 12:50 PM
Thank you both for your replies. I did a little searching last night and found thousands of sites with kits and such using the 555 timer, I even found one completely assembled that doesn't need external power, just 110v - it powers the circuit as well as feeding the relay - $9.95!
Thanks!
Gary
Displaying Cycle Timers while running? donl517 Fadal 5 10-01-2007 10:12 AM
555 Timer not triggering other 555 timers Smertrios General Electronics Discussion 3 10-05-2006 07:16 AM
The Countdown Has Started OneCNC OneCNC 42 01-21-2006 08:36 AM
Looking for a relay controller with timers. Kmed General CNC (Mill and Lathe) Control Software (NC) 3 02-21-2005 12:22 PM
