I have searched, and cannot seem to find the answer, just repeats saying use NO for home and NC for limits. I see why using NC for limits makes sense, cause if I wire breaks, it trips the limits. Why is it important to use NO for homes? i have the Soundlogic Bob C. BOB and it is for a plasma table. I am curious, cause the switches I ordered, the NC switches will give better repeatability cause the arm is stiff compared to the NO switches I got, and I have extra. Oh and Im using mach 3. Anyone know why? ![]() Thanks Brian Last edited by Wolfesmetalfab; 01-01-2009 at 09:10 PM. |
Gary |
| thats what I thought, but i see lots of people saying NO for home. Anyways with the soundlogic board has anyone successfully used NC switches hooking them to their designated home and limit inputs on the BOB? It says in the manual, that if you use NC tell Mach in the active low settings. I did and it wouldnt work. I believe if i read and am thinking right, that the home and limits on the soundlogic are connected onboard in parallel and this is why the NC switches do not work, but NO do? Can anyone verify what I am thinking, so I dont go and buy more NO switches if I dont need to cause I have a bunch of NC. Or how did you hook your NC up to the Soundlogic. Brian |
| I think it is more a matter of choice. Sometimes people look at a thought and then it becomes gospel. You are correct in the reasoning for the operation of the limits. In the case of home switches, it is less of a "hazard" if the system doesn't work due to a broken wire. However having said that, I agree it will help point to a problem if you try to home and it goes in the wrong direction; so this is one reason why mine are also NC switches for homing also. As long as you properly configure your system, it should work just fine. I cannot help you with your particular bob as I don't have one.
__________________ Art AKA Country Bubba (Older Than Dirt) |
| Gary |
What I am thinking I will do, is use 3 pairs of wires going out from just the limit connections and wire 2 switches NC in series and not hook anything to the Home inputs on the BOB, and then tell mach what Im doing for home direction, and I think it should all be good. |
| Here's a good discussion of home/limit switches: http://www.cnczone.com/forums/showthread.php?t=24432 CR. |
| Home Switches | elogicca | Carken Products (Deskam, DeskCNC etc) | 1 | 04-14-2008 09:04 AM |
| The relationship of limit switches to home switches. | MikeAber | General Electronics Discussion | 4 | 11-04-2004 01:28 PM |
| Limit switches and home switches | viktorcnc | TurboCNC | 2 | 08-03-2004 06:11 AM |
| Home switches and limit switches. | ynneb | General Electronics Discussion | 5 | 04-08-2004 05:32 PM |
| Home switches | andybuch | DIY-CNC Router Table Machines | 5 | 06-16-2003 02:54 PM |
