Old 12-31-2008, 08:48 PM
WeCheat's Avatar
Gold Member
WeCheat is on a distinguished road
Lost on the math yes I am
Ok I am not getting anywhere looking at inverters for my truck. What I don’t know is how much I need from the truck. For example I have 14vdc making 70amp I get 980 watts right? They say most inverters are 80% efficient so when you run that 980watts DC in the inverter to turn it into AC I would get how many watts AC? Also whats the formula for this to convert DC to AC? Some say if you have like a 2500watt inverter you need 250amp DC to make it work.
Thanks for your time and help!!!
Old 12-31-2008, 10:02 PM
rfwyzard is on a distinguished road
Volts times Amps equals Watts. 14 volts times 70 amps = 980 watts. Times .8 for 80% = 784. Divided by 120 volts equals 6.5 amps. Truck battery, ignition and computers need power to keep the truck running. You didn't say how much power you need for your accessory but if it's much more than 4 or 5 amps especially on a long term basis you're going to need a MUCH bigger alternator. A second unit would be a good idea. Or maybe a generator in the back, then you wouldn't need to run the truck. A second battery with an isolator is a good idea also. Check out a trailer or RV store. They can tell you exactly what you need.
Old 12-31-2008, 10:04 PM
bharbour is on a distinguished road
output power in watts = input current * input voltage * efficiency in percent/100.
If you want that output power converted to current, divide it by the output voltage (120 or 240). This is a bit of an oversimplification because it ignores power factor, but that is another critter. Be aware that startup currents on motors can be 5x the operating current. Similarly, startup current on incandescent bulbs can be 3X the operating current. An inverter needs to be able to supply the startup current without sagging or exploding.
BobH
Old 12-31-2008, 10:32 PM
WeCheat's Avatar
Gold Member
Thanks that is what I needed. You are great!
math help the4thseal General CAM Discussion 3 08-28-2007 09:09 AM
Math help wcarrothers1 DIY-CNC Router Table Machines 6 10-20-2006 06:30 PM
Check my math!!! (Please) Hack General Electronics Discussion 19 04-15-2006 06:18 PM
Need some math help... kanankeban Mechanical Calculations/Engineering Design 18 04-03-2005 03:27 AM
Need help with math replicapro General Metal Working Machines 7 07-27-2004 09:08 PM
