Old 12-22-2008, 01:43 PM
jdgriffin is on a distinguished road
Wireless Transmitter
My shop is equipped with a dust collection system that is turned on-off by remote wireless (RF) transmitters.
I would love to incorporate a transmitter into my CNC mill that could be activated by an M code.
I've searched the archives with no success. I'm wondering if someone has incorporated something similar into their design. Any direction would be appreciated.
Old 12-22-2008, 02:12 PM
LaserImage is on a distinguished road
I'm not an electronics guy so don't ask me how to wire this up, but what about using a relay to trigger the switch on the remote?
Gary
Old 12-22-2008, 03:12 PM
Gary -
I've thought about doing that, but it appears to be more involved than I had anticipated. The remote has two switches (one on/one off), and they are part of the circuitry soldered to the BSB.
Old 12-24-2008, 12:39 PM
bharbour is on a distinguished road
Originally Posted by jdgriffin View Post
Gary -
If you have a breakout board (BOB) with a spare SPDT relay, here is a verbal sketch of a way to drive the two buttons from that one relay:
Tie the Normally Closed contact of the relay on the BOB to ground. Tie the Normally Open contact to +V (5 or 12 volts).
Connect the Common pin of the relay to the + end of a 1000uf electrolytic capacitor.
Get a pair of ordinary diodes (1N4004 or similar).
Connect the anode of one diode and the cathode of the other diode to the capacitor - lead.
Get a pair of the little reed relays. If you used a 5V power supply, get 5V relays or if you used a 12V supply, get 12V relays. Connect one end of the coil of each relay to the other ends of the diodes. Connect the other end of the reed relay coils to ground. Connect one reed relay contact pair across the on button and the other relay contact pair across the off button of your remote. Note that some of those reed relays have diodes built in, avoid that variety.
The way that this circuit works is that switching on the relay on the BOB applies +voltage to the capacitor and charges it up through a reed relay coil. The reed relay that switches on will be the one that has the diode anode connected to the capacitor. The other diode will block and it's relay stays off. The capacitor will charge up, current will stop flowing and the first relay will switch off. When you turn off the relay on the BOB, the + end of the capacitor is now grounded and the - end will be below ground. The diode with the cathode on the capacitor will now conduct and turn on that relay until the capacitor discharges. This may take a little fooling with, but should work OK. To get the reed relays to stay on longer, increase the capacitor size.
Sorry for the verbal description instead of a sketch, I am not in a place I can scan a sketch in.
Bob
Old 12-25-2008, 12:22 PM
Bob -
Thanks for the reply. That sounds like a great solution.
I like the idea of only needing one pin.
Thanks again for taking the time to reply.
Anyone Using Their G100 Wireless? Clockwork G-REX 3 06-26-2010 10:20 PM
wireless Mr Bits LinuxCNC (formerly EMC2) 4 11-17-2008 11:48 PM
Digi Wireless kccrusher Machine Problems, Solutions , Wireless DNC, serial port 0 10-03-2008 10:57 AM
wireless RS232 jonplace Machine Problems, Solutions , Wireless DNC, serial port 1 04-16-2007 09:21 PM
DNC Wireless Graphcon Machine Problems, Solutions , Wireless DNC, serial port 0 01-15-2004 10:12 AM
