Old 12-12-2008, 03:38 PM
bob1112 is on a distinguished road
Electrical help on buck/boost transformers
Not sure where to post this anymore. Thought there was a VFD/Electrical forum????? Anyway, please move if needed.
Looking for info on single phase buck/boost transformers. curious if 12/24 and 16/32 transformers can only buck and boost at one percentage in an auto transformer configuration? thought I remembered them capable of other configurations??? ie, 12/24 = 10% and 16/32 = 15%, etc. Also looking for some basic equations to figure the kva. we determined we only need a 1.5kva transformer to buck 10% on a 15kva. load. Obviously the more you buck, the less kva the transformer will handle. We want to buy a 12/24 but may need to go more than 10% to make a control happy. hate to have to get another if it is nor enough.
Old 12-12-2008, 03:55 PM
Al_The_Man's Avatar
Virtually any transformer can be used in a buck/boost manner. The same current is carried by the B/B transf. as the main transformer, so the VA calculation is the same.
Secondary current x secondary voltage.
Old 12-16-2008, 04:03 PM
svenakela is on a distinguished road
Moved to the general electronics.
Boost and sleep mode mr.praktik LinuxCNC (formerly EMC2) 7 01-17-2008 06:52 PM
Buck and Boost Transformers Mr. Technical Bridgeport and Hardinge Mills 3 08-19-2007 09:55 PM
Found a good source for small stepper driver transformers! $3 25v 2a transformers. radicooldude General Electronics Discussion 3 05-02-2006 02:15 PM
TM 2 Spindle Speed Boost Motivator-1 Haas Mills 5 02-15-2006 11:09 PM
Boost PC ATX Power Supplies to 24v..32v ggg General Electronics Discussion 3 12-30-2005 08:24 AM
