Old 12-07-2008, 08:27 PM
Tony611 is on a distinguished road
Question Nema 34 driver boards
I have some driver boards that are designed to run Nema 34 stepper motors.
Can I use them to run Nema 23 stepper motors?
Old 12-08-2008, 06:28 AM
jalessi's Avatar
jalessi is on a distinguished road
Smile
Tony,
If the stepper driver is Bipolar any Bipolar or Unipolar motor will work as long as the driver current output is adjusted to match the motors current requirement (amp draw).
If the driver is Unipolar then only Unipolar motors will work as long as the driver current output is adjusted to match the motors current requirement (amp draw).
If the driver is 5 phase then only 5 phase motors will work as long as the driver current output is adjusted to match the motors current requirement (amp draw).
The current applied to the motor will determinate its torque.
The voltage is not so critical, it corresponds to the motors peak r.p.m..
The term Nema 23 or Nema 34 is a specification for the physical frame size dimensions of the motor not its current or voltage requirements.
Jeff...
Need Help!- Optocoupled driver boards alphamail General Electronics Discussion 9 09-29-2008 03:18 AM
Need Help!- Looking for new Driver Boards: Please Help SpeedsCustom Benchtop Machines 19 06-13-2008 07:54 AM
cheapest driver boards - nearly there. droddis DIY-CNC Router Table Machines 8 12-14-2007 08:18 AM
cheapest driver for nema 17 bipolar stepper motor cheater76c Stepper Motors and Drives 3 02-28-2006 08:30 PM
Driver Boards?? mocnc DIY-CNC Router Table Machines 9 12-13-2005 09:04 AM
