I am converting a Chinese 9x30 lathe to CNC. (http://www.cnczone.com/forums/showth...t=63621&page=2) I want to be able to cut threads, so I need a spindle position encoder. The lathe uses a pair of sealed bearings for the spindle, so the outside of the spindle shaft is in open air in the head casting. I am thinking of simply laser-printing two black/white tracks (20 pulses per rev + index) onto paper, wrapping this round the spindle with tape, and then using a pair of Optek OPB702 reflective sensors to watch the stripes go round. Is there any reason this won't work? My first thought was a machined aluminium disc, but I suspect my inkjet printer can print tracks more accurately than I can machine a codewheel, and this approach saves me dismantling the head. |
| Years ago I did a similar thing but it was lines drawn with a drafting pen; laser printers were not even a gleam in anybody's eyes back then. If your reflective sensor are not already shrouded make a housing so they are looking through a slit about the same width as your lines. This gives crisper definition to the signal. Also, surely 20 pulse per rev is a bit coarse? One pulse every 18 degrees.
| Have you considered putting an encoder inside the spindle compartment and using a encoder pressure wheel against the spindle itself? the compartment is a relatively clean and protected environment. BTW, you only need one reading head, unless you want to indicate direction, or up the resolution by using the multiple edges (80 counts/rev). Oops, yes you need one for marker. Al.
| Andy, I cut an encoder wheel on my cnc router with 100 holes plus index. I am using it on my 9x20 spindle. You can see the build up of the spindle encoder here starting at message 48 and following intermittently through the thread. Alan
__________________ http://www.alansmachineworks.com |
| I was trying to minimise the requirement for high-speed switching electronics and parallel port bandwidth. However having just calculated that my computer worst-case latency of 18uS allows me at least a million pulses per rev at 3000rpm, I might go for a finer resolution. |
Inside the compartment is where I intend to put the encoder (it is also nice and dark in there). However surely a pressure wheel would be very unlikely to run at exactly the same speed as the spindle, leading to a disasterous cumulative pitch error when threading? |
| Looking at that encoder wheel above, it occurs to me that with reflective sensors you could make an encoder wheel very easily indeed out of an inkjet printable CD. In fact I might consider that possibility for making absolute encoders for my ballscrews. |
| Al.
#10
| Actually, it might work, as during a thread cutting operation the spindle probably only goes round a few hundred times so if the roller and spindle diameters are within a couple of thou the cumulative error in the thread starting position will be only a few degrees, which is probably OK. Nevertheless, if this idea doesn't work then Plan B is a machined/drilled aluminium disc machined in two parts to clamp round the spindle. |
#11
| Slip should not be a worry so long as it was constant; not a worry for threading that is because the spindle does not reverse. It would be a different situation for rigid tapping.
#12
| Alan
| idea for cheap but very accurate linear scale | henry_phd | CNCzone Club House | 1 | 10-17-2008 11:04 AM |
| cheap linear bearing idea... | billyinks | DIY-CNC Router Table Machines | 4 | 04-12-2008 03:21 PM |
| Drill+encoder = cheap servo? | sandos | DIY-CNC Router Table Machines | 11 | 04-26-2005 01:58 AM |
| Here's an idea for a cheap bellows style ballscrew cover | DR-Motion | DIY-CNC Router Table Machines | 31 | 02-16-2005 04:00 PM |
| Servo idea: Windscreen-wiper motor w. homemade encoder | Evilness | DIY-CNC Router Table Machines | 2 | 05-03-2004 01:24 PM |
