Old 11-26-2008, 10:57 AM
Oviksnc is on a distinguished road
Problems starting up Heidenhain Tnc155
Hi. Me and my friend is trying to figure out whats wrong with his 3-Axis Cnc mill with Heidenhain Tnc155. The previous owner lost the battery power so my friend bought this machine not working, but the machineparameters are back where they belong now and this is the problem we have. We start the machine ( 400v three phase ) and the system starts up. Then the TNC says something in Swedish wich is hard for me to translate ( power off or something like that ) you clear it with CE. Then is says something like this, sorry if iīm translating wrong- The feed for the relay is missing. This is when youīre supposed to press Machine on. And this is where it stops. Nothing happens, i think weīve checked almost everything. Looks like we have powersupply to all components, i have also measured the "power on" signal to the I/O board in the machine and itīs there. On my machine you can hear the contactor activating the servotransformator when pushing "machine on" but in this case.. Nothing .. All the fuses seems ok and the wiring looks ok.
The machine is a make: Modig and is Swedish
Anyone that can help in any way? Please =)
Thanks.
/Johan.
Sweden.
P.S Hope this message makes any sense
OviksNC/Sweden.
Old 11-26-2008, 02:59 PM
RMARCH's Avatar
RMARCH is on a distinguished road
You have to pull out the emergency stop button, Then power enable.
Old 11-26-2008, 11:58 PM
Hi.. Yes we did that, on further investigation i started up my old Tnc 150 yesterday and noticed that on startup it says power off. Then when you press CE this alarm that my friend has is coming up for a short moment, then you hear a light "click" i think itīs somewhere in the control panel and then the screen is changing to the referense search on the axis. This is where i push the power on so i can drive the Axis. So itīs somewhere between the CE clear and the Power on commando. Something that doesīnt get itīs signal ( a relay maybe? ) Does any of you know?
Thanks.
/Johan.
OviksNC/Sweden.
Old 12-03-2008, 06:46 AM
bigtoad170 is on a distinguished road
I think it is saying relay ext. dc voltage missing if you already checked the emergency stops then check the way oil believe it or not on my bridgeport if it is low you will get that same error code. I'm not sure if yours is the same but give it a try
Old 12-03-2008, 03:15 PM
Is that the oil for the hydraulics or the oil for the lubrication on the axles?
Thanks,
We will have a look. On my Bridgeport i can only see this notice for about a second and then something "clicks" from what i can hear inside the operator control and the machine jumps to the reference search screen.
/Johan.
OviksNC/Sweden.
Old 12-03-2008, 06:10 PM
RMARCH's Avatar
I Think Bigtoad was saying check the way Lubricant.
Old 12-04-2008, 06:31 AM
Yes check the way lubricant. My bridgeport also flashes that error quickly on every startup but if it stays on then it is either a emergency stop that is on or way lube is low. That clicking sound your hearing is just a contactor
Old 12-04-2008, 02:41 PM
Hi.. Allright, i will check that on Saturday, will tell you how it went afterwards.
Thank you all for the help so far.
/Johan.
OviksNC/Sweden.
Old 12-06-2008, 08:44 AM
Hi there Again
Ok we have been in my friends garage today and continued looking at the mill. All the oil levels are fine, and air to the machine is there. Apperantly before he bought this machine the previous owner lost the battery voltage for the memory. And some guy have been installing the machine parameters again, after this the machine haveīnt worked at all. We have been measuring all the power supplyīs and canīt find anything wrong with it. Today we checked all the sensors and oil levels. But nothing. The machine is a Modig 3 axis with tool changer.
Anyone have any ideas? Could this problem be machine parameter related?
Thanks.
/Johan.
OviksNC/Sweden.
Old 12-06-2008, 12:55 PM
Jukka Honkanen is on a distinguished road
PLC program in RAM?
Check your machine parameter 77.
If it is 0, then your PLC-program was in the RAM-memory.
And when the battery was gone, so was the RAM-memory and the PLC-program.
Jukka
  #11   Ban this user!
Old 12-06-2008, 03:02 PM
Jukka
Hi.. But how do i enter the parameter input menu now when i canīt even get the machine past this alarm? It doesīnt response in any button on the control. Seems pretty stuck at the moment
/Johan.
OviksNC/Sweden.
  #12   Ban this user!
Old 12-06-2008, 05:11 PM
MP 77
Do not clear the first message "Power Interrupted" but press the MOD-button.
Then you are able to key in the parameter code 95148 and check the parameter.
Jukka
HELP!! Heidenhain PC interface Problems servocontroller Bridgeport and Hardinge Mills 4 06-11-2009 06:05 AM
Spindle Starting Problems dkaustin Tormach PCNC 2 08-06-2008 06:09 PM
Contouring problems Heidenhain 155 praest General CNC (Mill and Lathe) Control Software (NC) 12 09-14-2007 05:53 AM
Need help with a Heidenhain TNC155 Post!!! Kim Post Processors for MC 3 11-09-2006 02:31 AM
Still struggling with the Heidenhain TNC155 plane magic Bridgeport and Hardinge Mills 3 10-26-2006 05:07 AM
