This could be a stupid question but when you measure the voltage on your parallel port with your multimeter shouldn't you see the standard 0/5v signals or therebouts? I'm just trying to test my L297/298 driver with a small motor. I'm using the EZCNC controller software. I can see the voltage fluctuate on the appropriate pins when I jog or command movement but it's really weird voltage levels like 178 mV. The parallel port on this old computer could be shot for all I know. Or is it possible that these voltage levels are floating since there's no load? Anybody see what I'm doing wrong. |
| Okay, Does that hold true even for signals that are held high or low? For example the direction signal should be either 0 or 5V. I assume it is held high or low for the duration of the commanded movement which could be several seconds. |
| The direction signal should stay at either0V, or 5V, depending on which direction you're going.
| C++, Win XP, Parallel Port | Zumba | Coding | 7 | 03-29-2012 01:12 PM |
| parallel port | wantsout | General Electronics Discussion | 15 | 09-23-2008 11:49 PM |
| 7812 Voltage Regulators in Parallel? | georgeburns | General Electronics Discussion | 10 | 05-23-2008 04:14 PM |
| USB to Parallel port? | TheDude | Hobbycnc (Products) | 6 | 03-24-2008 11:04 AM |
| Parallel Port | Shanghyd | Computers and Networking | 1 | 11-22-2004 11:56 AM |
