Old 11-09-2004, 10:37 AM
ccm ccm is offline
ccm is on a distinguished road
Clarification Needed - (warning Noobie content )
Real easy question, which I don't believe anyone has posted... yet that I've come across.
When you have the spec's on a stepper, and It' rated for X.XV & X.XA per phase, does this translate to (for ex: )
If the ratings are 2V & 2A on the motor, then it requires 2VDC but 4A to run the motor for the rated output.
So my motors are 1.7V & 4.7A, so my thinking is : 9.2A for each motor will be the minimum that I'll need, ..... or would I cut that spec in half?
So it's 2.35A per phase which then brings it to 4.7A total ?
-Art
Old 11-09-2004, 11:35 AM
*Registered*
ESjaavik is on a distinguished road
I would not be able to explain it half as good as this guy:
http://www.cs.uiowa.edu/~jones/step/
If doing anything with steppers beyond hooking up a system by a manufacturer's user manual, that is the place to start.
Clarification needed on current limiting resistors ccm General Electronics Discussion 1 01-11-2005 09:16 AM
