Old 11-07-2004, 09:58 AM
Wanna be
Hack is on a distinguished road
Cutting circles and arcs
I am under the impression that some controllers have a harder time cutting circles and arcs. Why is this and what do I need to look for when selecting a controller as my machine will cut a lot of circles / radius etc.
Check out what I am working on at www.routerbitz.com!
Old 11-07-2004, 09:16 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
The one thing to look for is a controller with constant vectoring.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 11-08-2004, 11:39 AM
HomeCNC's Avatar
HomeCNC is on a distinguished road
It's not only the controller that can cause poor results when milling arcs and circles. If you don't have a tight machine with very little backlash you will see problems on cut circles in the 4 quadrants. This is where the motor must change direction and this is where you will see the quality of your machine. If you have see small gouges or flats on the 4 quadrants of a circle then your machine has some backlash that is causing this.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 11-08-2004, 02:31 PM
OCNC is on a distinguished road
Is this a hardware or software issue?
Chris
Old 11-08-2004, 03:12 PM
CNCadmin's Avatar
Site Owner
CV is done in the software, I believe that some can be controlled by hardware not sure on that one.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
AutoCad To Mach2 massive arcs circle. dont know what to do bdesh123 Mach Software (ArtSoft software) 2 04-12-2005 07:38 PM
