Old 11-07-2008, 02:59 AM
xinzc28 is on a distinguished road
need help to connect microcontroller to stepper driver
I build my driver board using L6203+L297+74HC14N
at 74hc14n input stage, I put 10k pull up ( i'm expecting my AVR to sink to make it "low" )
To test the driver board, I using AVR microcontroller to send signal clock & other inputs.. but it failed and even damage my L297 chip
there are 2 boards, the 1st is the stepper driver, the 2nd is the AVR board
each one of them use different power source & ground. could it be the problem?
Need Help!- How to connect 3A Bi-Polar Stepper Motor Driver from arceurotrade cor Stepper Motors and Drives 2 03-29-2008 09:43 AM
serial port+microcontroller visky General Electronics Discussion 1 10-28-2007 08:48 PM
Wanted DIY stepper driver circuit for 6 wire stepper motors Colin300 Australia, New Zealand Club house 5 09-20-2007 09:20 PM
STEPPER DRIVER FAQ {Stepper/driver amp per phase match. huios Stepper Motors and Drives 0 08-27-2006 08:43 AM
Discrete transistors and AVR microcontroller DukerX Open Source Controller Boards 26 03-04-2006 07:30 AM
