Hello all, I have a quick question I got 3 stepper motor from a friend that I have some quesions about. The Specs are (As printed on the back of the stepper) 12 Volt 1 Amp PPS 0-200 RPM 0-250 Made By AirPax My questions are 1 - @ 12v 1 amp what would you guess the oz power would be? 2 - Does this sound like a adaquate stepper for a small cnc plasma cutter I am going to build. 3 - Does the PPS (Pulses per second) make much difference and is 200 about normal? 4 - Last one I swear!! It take about 24 steps for a complete rotation, that make it about 15 degrees per step right, isn't that really high?? Thanks for your help, These are the only spec I can come up with as I can't find any information on the web about it. |
| bcromwell, Those steppers, if they are 24 steps per rev, will probably not be ideal. 12 volts is not ideal either. If I were you, I would look for 200 PPR (1.8 degree step) steppers at around 1 to 2 amps and +/- 5 volts. These can be driven by an inexpensive driver board and power supply and will have good resolution/ torque. I am guessing your steppers are low in the way of torque, probably in around 20-40 oz in. Eric
__________________ I wish it wouldn't crash. |
Bryan |
| Most drivers are just like a switch you put 12 volts on one side of the winding and you close the switch and the switch only sees the voltage between it's ground and its collector (if a transistor switch). Look at the specs on an inexpensive driver board and how they wire the stepper to it. |
| Mixing servo and stepper | ty1295 | Servo Motors and Drives | 0 | 01-19-2005 10:26 AM |
| Attaching a Stepper | andy_ck87028 | DIY-CNC Router Table Machines | 4 | 12-24-2004 12:09 PM |
| Not good for a stepper motor? | FLUTE HEAD | Stepper Motors and Drives | 4 | 12-02-2004 12:31 AM |
| Fun with floppy stepper and driver | Konstantin | General Electronics Discussion | 5 | 03-08-2004 02:18 AM |
| disassembly of stepper motors | dhprc2 | General Electronics Discussion | 8 | 06-25-2003 08:09 PM |
