Old 11-03-2008, 12:59 AM
dodod3d3 is on a distinguished road
Cool DRO output as limitswitch
Dear all,
I need help from all ....
I using Sony DRO (Digital Readout system) for Milling Machine with auto feeder,i need using dro to control auto feeder. when the Dro displayed 0.000 the auto feeder will be stopped.any one have idea for this....?
Old 11-03-2008, 08:12 AM
srcmadison is on a distinguished road
Use a relay in series with the auto feed's mechanical limit switch
If the DRO has a programmable, digital output, you should be able to wire a relay to the output and then wire a set of normally closed relay contacts in series with, or in place of the auto feed's limit switch. Depending on the DRO output type you may need some additional components to drive the relay (such as an optically isolated digital out module and a power supply).
Old 11-05-2008, 05:29 AM
Question optically isolated digital out module
srcmadison,
Thank's for your help.forgive me if i'm not so familiar with electronic stuff.
The situation is DRO (The display unit)not programmable ,and digital output(not sure, because at back of display there's no other connector, except for linear scale unit), only linear scale has signal A&B output Signal(read from manual book).
It is possible to make interface(for digital output??/optically isolated digital out module) between linear scale or display unit so when DRO displayed 0.000 there's analog output to drive the relay?do you have any idea or schematic may be?
thank you for help and idea...
Old 11-26-2008, 04:31 PM
LMSC's Avatar
LMSC is on a distinguished road
Unless the Sony display has a output connector, you will not be able to interface anything unless you are a electronics guru. Sony systems are not compatible with the other dro systems on the market so using another manufactures display is also out of the question. I guess you could hire someone to build something that will interface with the Sony scale box on the end of the scale cable. The price would be what it would cost to buy a new system with the output in the display.
Regards,
Tim Barnard
LMSC
www.digitalreadoutsystem.com
Programmed RS-232 output ghyman G-Code Programing 13 07-11-2008 03:53 AM
Output to a Bandit? Chris64 SheetCam 31 10-07-2007 07:36 PM
Output arcs using R not I,J? LongRat SheetCam 2 06-20-2007 12:35 PM
torodial output seems odd trubleshtr General Electronics Discussion 3 04-21-2005 08:42 PM
Output is mirrored?? BobLWeiss Carken Products (Deskam, DeskCNC etc) 3 01-03-2005 11:54 AM
