Old 10-31-2008, 10:26 PM
cnc kiwi is on a distinguished road
Optoisolator max frequency
Hi
Can anyone tell me whether or not a fairly standard optoisolator such as
http://www.datasheetcatalog.com/data...TLP521GB.shtml
this one will be able to work as an electrical isolator between my PC/s LPT and my CNC drivers step and direction pins. I wouldn't need any frequencies higher than 5kHz. So, will these optoisolators work fine at such a frequency?
Thanks a lot
cnc kiwi
Old 10-31-2008, 11:45 PM
martinw is on a distinguished road
Thanks a lot
cnc kiwi
Dear cnc kiwi,
At 5kHz, an opto-isolator isn't even "getting out of bed". You will have absolutely no problems as regards frequency as long as you stay within specifications elsewhere.
5kHz really is nothing
Best wishes,
Martin
Old 11-01-2008, 02:11 AM
epineh is on a distinguished road
The opto you listed has a forward input current of 50mA from the datasheet, this is a little too much for the parallel port to sink and way too much for it to source, I am using PC817's for IO and HCPL 2630's for step/dir though for 5KHz the PC817 should be fine, it has an input current of 20mA and if you use them active low the P.Port should be OK.
Cheers.
Russell.
frequency inverter visky Want To Buy...Need help! 3 09-08-2010 05:13 AM
Optoisolator question farmallfan Open Source Controller Boards 7 07-24-2010 06:50 PM
HELP! Increasing frequency... WilliamD General Electronics Discussion 4 04-23-2007 04:32 PM
Optoisolator circuit andy55 General Electronics Discussion 60 01-15-2007 12:12 PM
Step frequency drk Gecko Drives 2 11-21-2004 07:41 AM
