Old 10-26-2008, 04:18 PM
visky is on a distinguished road
Parallel port+ input pins for use with EMC
How to wire opto 4n25 and inverter 74hc14N for input pins on parallel port?
10-13 and 2-9 pins
1.collector pull up resistor 3k3ohm,5volt over inverter to the printer port pin and emitter to ground?
2.collector pull up resistor 3k3ohm resistor,5volts and emitter over inverter to the printer port pin?
Or i should use any other ICs?
Marko
Need Help!- optical interrupt input into parallel port?? antichip LinuxCNC (formerly EMC2) 1 09-07-2008 04:28 AM
Flash drive USB to parallel or serial port input lowtech4 Computers and Networking 0 03-03-2008 03:45 PM
Parallel port input pin high/low mike944 General Electronics Discussion 7 02-01-2008 09:42 AM
parallel port input problem stirling General Electronics Discussion 11 10-22-2007 01:10 PM
Configuration Of Output Pins In Parallel Port FOR 4 AXIS Khalid Open Source Controller Boards 2 05-20-2007 01:55 AM
