Old 10-27-2004, 10:43 AM
S.R. Stoene is on a distinguished road
G-code to Electronics?
Hello,
I'm in an E.E. Sr. Design Lab and we hope to build a 2-axis cnc machine as our project. My quesiton is how does G-code translate into electronics (IC, Micro-controller, PC)? Is there an industry-standard approach? S. Stoene
Old 10-27-2004, 12:28 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
The NC (numeric controller) takes the g-code and converters it into pulses that, than get feed into the drivers that sends info to the stepper/servos.
(someone correct me if I'm wrong)
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 10-27-2004, 01:41 PM
abasir's Avatar
abasir is on a distinguished road
Originally Posted by S.R. Stoene
Hello,
It's the other way round. The electronics is supposed to translate the G-Codes
G-Codes basically consist of movement (multiple axis) instruction as well switching instruction for spindle, coolant, etc. Your 'translator' will have to read the G-Code and electronically control the respective devices (stepper motor, servo, relays, etc)
Stupid questions make me smarter...
See how smart I've become at www.9w2bsr.com ;-P
Old 10-27-2004, 02:17 PM
mvaughn's Avatar
Moderator
mvaughn is on a distinguished road
Since you are in and E.E. Major you should check out the Open Source Controllers Forum. Check out the designs in there, they may give you a better understanding or starting point for learning how software translates g-code into pulses that the circuits translate into step and direction signals.
Mark
Check Out My Build-Log(s):
http://cnczone.com/forums/showthread.php?t=4716
CNC Router Version 1 [====================] 100%
http://cnczone.com/forums/showthread.php?t=39294
CNC Router Version 2 [=|-----------------------] 5%
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 09:21 PM
EZ Trak and G Code melamark Bridgeport and Hardinge Mills 23 05-05-2006 12:03 PM
parametric programming Karl_T CamSoft Products 21 05-24-2005 02:58 PM
I need sample G code program bunalmis G-Code Programing 1 08-24-2004 03:50 AM
Getting The Most Out of CNCzone's Posting Features CNCadmin CNCzone.com FAQ 0 03-01-2003 11:08 PM
