Old 10-13-2008, 01:30 PM
joprinz is on a distinguished road
Lightbulb Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver?
Hello Everyone,
I'm designing a 50V 8A+ Bipolar Stepper Motor driver. I'm new to Discrete H-Bridges and plus I'm not very familiar with all the new MOSFETS and MOSFET Drivers in the market. I was wondering if you can share your experience with MOSFETS and MOSFET Drivers.
So far the Drivers I came across are
  • Intersil HIP4082
  • IRS2304
  • Microchip TC4424
And The MOSFETS
  • STF40NF06
  • IRFZ24
  • IRFZ44
  • IRF9530 and IRF540
Well I came across plenty of other parts as well. Lets jus say the more U seek the More U find in this case. Just before I decide on one part I come across another which seemed better(btw My knowledge on MOSFETS is Very Limited. So cant really say if its Really a Better one I jus found). So I was wondering if someone can help me pick the right Driver and MOSFET for a Driver with the following Specs
  • Dual H-Bridge (MOSFET) Bipolar Stepper Driver 8A+ @ 50V
  • Step Sequencing will be done using a PIC or Atmega uC
  • Step Rate will be in the range of 2000-3500 Pulses/Second
  • Current Limiting is done using an External PWM @ 20kHz
Please Advice!
Thank You.
Joe!
Old 10-15-2008, 08:56 AM
JRoque is on a distinguished road
Hello Joe,
My two cents: I've used the HIP4081A which is similar to your choice. I had a hard time getting rid of a sneaky current loop so I would recommend you watch out for proper layout and use a single ground return point.
As for MOSFETs - and I'll likely draw the ire of some here with this comment - I'd go for the lowest RDSon on a rated device. Highspeed, etc are not that important in this application. Keeping in mind also that voltage rating should be high enough to account for motor back EMF and a few techniques like a parallel diode across the FET input resistor helps drain it quickly and avoid cross conduction.
I like Atmel micros better than Microchip's but that might be a moot point soon if Microchip succeeds in gobbling up Atmel. Doh!
JR
Old 10-16-2008, 09:31 PM
Thanks JR for your input
I was told IR2104 and IRF540N is a well tried n tested pair to use in H-Bridges. I'm currently looking at using them in my driver.
Please share your experiences using the IR2104 and the IRF540N.
Thank You,
Joe!
Old 08-23-2010, 10:10 AM
bedrive is on a distinguished road
i vote for 540 and irs2104
b.r
Old 04-28-2011, 03:57 AM
vishal pandey is on a distinguished road
Hello Everyone,
i am looking to bild H-Bridges.stepper driver using IR2184 and IRF540N anyone can help me
thank
Need Help!- L297 with MOSFET H-Bridge joprinz Stepper Motors and Drives 62 04-07-2011 01:47 PM
Mosfet Driver tivoidethuong General Electronics Discussion 57 01-18-2009 09:20 PM
mosfet h-bridge design visky General Electronics Discussion 6 06-11-2008 03:51 PM
Experiance with the HIP4082 mosfet driver? AbSat General Electronics Discussion 0 07-01-2007 06:17 PM
IR2184, HIP4080A, or other for mosfet driver? originator Stepper Motors and Drives 2 11-02-2006 09:31 PM
