Old 10-12-2008, 02:29 PM
erkiwi is on a distinguished road
Smile What is the difference 0 volts and Ground?
Hi,I am wiring up my limit switches and one end needs to be connected to 0 volts.Is this the same as ground,also on my breakout board I have a com connection is this also 0 volts?
Eric
Old 10-12-2008, 02:36 PM
Karl_T's Avatar
Karl_T is on a distinguished road
No, not really. You have to be careful how you handle DC common or you get ground loops and weird sh*t happening.
I run all DC commons to a terminal strip where everything is connected together. Then one and only one connection from this to ground. Special note: keep this separate from the AC nuetral.
Al-the-Man posted a nice articlle on this subject a while back.
Karl
P.S. 0 volt and DC common are two ways to say the same thing
Old 10-12-2008, 03:06 PM
Al_The_Man's Avatar
Unfortunately the makers or BOB's etc, often use the term Ground, when they mean Common, which may or not, be grounded.
Too bad, To the new comer to the electronic side, it can get confusing or misleading.
Old 10-12-2008, 04:43 PM
TOTALLYRC is on a distinguished road
I find it really gets confusing when they mention +12v and -12v and they don't mean switch the wires around.
Ground and Common get used interchangably when they may or may not be the same thing.
Old 10-12-2008, 07:26 PM
Al_The_Man's Avatar
Yeah, That gets a bit misleading, what that means is, you have changed the reference point.
Unless it refers to -12v supply WRT to the COMMON reference
120 Volts? BrendaEM Industrial Hobbies (Support forum) 11 04-08-2008 08:24 PM
Need Help!- To Ground or not to Ground That is the question! Mr.Chips DIY-CNC Router Table Machines 1 03-16-2008 03:10 PM
5 volts to 1.5 volts? ZipSnipe General Electronics Discussion 5 08-18-2006 05:18 AM
Boosting three-phase 240 Volts to 480 Volts Old Car Guy Phase Converters and VFD 6 05-01-2006 09:27 AM
Motor supply ground vs Logic ground? Gashmore General Electronics Discussion 11 06-07-2005 05:21 PM
