Old 10-25-2004, 12:18 AM
Sanghera is on a distinguished road
Parallel Port Wire Length?
How long can the Parallel Port Wire be without losing a signal. I've seen some really long extension cables.
Thanks.
Old 10-25-2004, 08:15 AM
kong is on a distinguished road
I think the one for my lathe is 4-5 meters long. It goes up the wall, across the ceiling then down the other side. No loss of signal that I know of. Actually, it then goes into a parallel port switch box, which is connected to the PC by another cable, about 1 metre long.
Old 10-25-2004, 09:48 AM
*Registered*
CNCPlastic is on a distinguished road
They make 25 foot printer cables and they work just fine for printing so I'm sure it would meet cnc needs. Mine is about 15 feet and works just fine.
Old 10-25-2004, 11:30 AM
Shop Rag is on a distinguished road
If the cable is shielded you can get by with 100 feet. Also be sure not to run the cable next to any electrical divices.
Old 10-25-2004, 02:51 PM
Why is that?
Thanks for the help.
Old 10-25-2004, 05:51 PM
sol sol is offline
Gold Member
sol is on a distinguished road
Long wire = antennae...picks up electrical noise from other equipment.
Old 10-25-2004, 08:59 PM
How do you properly shield the cable?
Thanks.
Old 10-25-2004, 09:14 PM
c_nut is on a distinguished road
Sanghera
Buy it that way. Most if not all new cables are already shielded.
Just don't run the cable parallel to any cables carrying AC or porer DC. It can cross at an angle but not run along in line with them.
Old 10-25-2004, 09:15 PM
That was power DC. Sorry.
Old 10-25-2004, 10:16 PM
OK Thanks.
Old 10-25-2004, 11:15 PM
*Registered*
One more tip...only connect one end of the parallel cable shield to ground. I had connected both ends on my setup and suffered some very strange problems due to a ground loop issue.
  #12   Ban this user!
Old 10-26-2004, 01:47 AM
cbcnc is on a distinguished road
CNCPlastic,
That's a good point about only connecting the cable shield to a ground only at one end.
What is the shield connected to? Is the DB-25 housing grounded?
I run a male-male cable from the lpt port to my controller board. As far as I know the female housings are grounded at both ends. I will have to check that out.
I've had some noise issues that I have traced to the switch on my trim router and I am not sure where the noise is getting into my controller.
More questions than answers.
Chris
DNC with parallel port (Bridgeport BOSS 5)? hobbymat General CAM Discussion 3 07-20-2009 11:16 AM
Parallel port circuit Kerri Ann General Electronics Discussion 12 03-19-2005 12:23 AM
Parallel Port Options JasonCroyle General Electronics Discussion 4 01-12-2005 07:23 AM
Parallel Port / Relay Control Question Verboten Computers and Networking 7 12-21-2004 04:17 PM
Parallel Port Shanghyd Computers and Networking 1 11-22-2004 11:56 AM
