Old 09-30-2008, 02:52 PM
kprice1658 is on a distinguished road
How to adjust rpm on this dc motor
Thought I'd try here to get some help for this project - since the other CNC forums are very helpful.
This is one of the types of motors that I have : http://www.surpluscenter.com/item.as...50&item=5-1676
(there is a little wiring diagram on the wiring tab on the page)
Trying to figure out what I need and specs on what to buy to be able to control this motor for adjusting rpm, forward/reverse and input voltage. I know a little electronics, but not sure how to get this done. I realize that I need a ac/dc transformer for the input, and probably a potentiometer to vary the rpms. Not sure what amps the transformer should be able to handle or the pot should be. No idea on how to forward/reverse it.
Old 09-30-2008, 03:11 PM
Al_The_Man's Avatar
My estimation you would need a 18vac secondary transformer around 100VA, one 10amp bridge rectifier, 10,000µf 40vdc capacitor, 2 SPDT toggle switch.
It does not mention the pot value but 5k ~ 10k should suffice.
Forward reverse is built in the controller CW/CCW?.
Old 09-30-2008, 05:03 PM
I thought it take a 120ac/24dc transformer? You say 18vac, I assuming that you're doing something with the bridge / cap ? Could you elaborate ?
Thanks for the quick reply.
Old 09-30-2008, 05:11 PM
Al_The_Man's Avatar
The transformer produces 18vac RMS secondary, this number is derived from your desired 24v x .707.
The 18v will produce ~24vdc peak DC voltage after rectification and ripple removal by the capacitor.
Peak DC is RMS (root mean square value of the AC) value x 1.414.
Old 10-01-2008, 01:44 PM
Sorry I asked - all over my head .
Seriously, I think I follow what you're saying. That'll give me clean voltage? I'll start looking for the parts you suggest. May need a diagram on how to wire everything up.
Will that transformer be relatively small? Form factor is a concern.
Thank-you.
Old 10-01-2008, 01:56 PM
p38nut is on a distinguished road
Smile Power supply
There is no such thing as a 120vac/24vdc transformer. That being said, the transformer, bridge, and cap make up a 120vac/24vac POWER SUPPLY which is exactly what you need.
As being a newbie, things will get very confusing as you get deeper into this, and then all of a sudden, wham, the light goes out completely. Ask me how I know!!
Old 10-01-2008, 02:05 PM
Al_The_Man's Avatar
There is lots of info on the web referring to bridge supplies e.g. http://www.kpsec.freeuk.com/powersup.htm
Also if you search here in the Electronics section, there are build details.
Hammond recommend no lower than 50va for this application, That will give you a transformer around a 2.5" cube.
Old 10-02-2008, 05:10 PM
keebler303 is on a distinguished road
Originally Posted by p38nut View Post
There is no such thing as a 120vac/24vdc transformer. That being said, the transformer, bridge, and cap make up a 120vac/24vDC POWER SUPPLY which is exactly what you need.
Fixed it for ya!
Matt
Old 10-02-2008, 06:55 PM
Thanks guys. Great link you provided. I'll do some reading to make sure I get the drift on the process. Hopefully, that "light" will start to glow a little...
I'll run my parts by you guys before I order anything...
How do I adjust the backlash S Lovette Shopmaster/Shoptask 3 03-15-2010 01:57 PM
Z axis how to adjust it cob Mach Mill 1 07-10-2008 04:59 PM
How do I adjust the Gibbs? CNCadmin General Metal Working Machines 20 05-13-2008 06:06 PM
how to adjust Backlash. cnccustom Syil Products 4 11-21-2007 12:28 AM
need help to adjust servo system webcruiser8 Employment Opportunity 2 11-27-2006 02:36 PM
