Old 09-26-2008, 09:07 AM
tahoka is on a distinguished road
Single Supply OPAMP instead of 741
Please can someone suggest me an alternative to IC 741 in the basic V to I converter and non inverting amplifier circuit as we require an opamp which uses only a single supply.
The input to V to I converter is 0 to 5 volts and output is 0 to 20 milliamperes.
the output of amplifier is 0 to 5 volts.
Old 09-26-2008, 09:39 AM
Gold Member
Mariss Freimanis is on a distinguished road
LM358 for a dual op-amp, LM324 for a quad po-amp. Common as dirt and cheap as dirt.
Mariss
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
Four Carriages on Two 15mm Rails or a Single Carriage on a Single 45mm Rail ??? joprinz Linear and Rotary Motion 12 10-07-2008 06:08 AM
Single to Three Phase Help, Please elalto General Metal Working Machines 20 01-04-2006 05:01 AM
110 single phase to 220 single phase. Nono General Electronics Discussion 36 06-05-2005 07:51 PM
cut single, cut auto and cut all??? fastolds BobCad-Cam 3 10-06-2004 08:15 AM
