Old 09-20-2008, 10:41 PM
Snipes44 is on a distinguished road
Power supply design for my JGRO.
Trying to figure out if this is going to work for my JGRO. Here is what I have
Hobby pro 3-axis board
3 - 23lm-c057-02 nema 23 steppers
2.6V 2.5A 1.8Deg 1.04 ohms
I have an old GE transformer that I pulled from some old control equipment. Here are the specs on that transformer.
part # 9T55Y47G2 Type 1P
Primary 460V/230V (There is a tab that you connect up depending on what input voltage is needed)
Secondary 115V
KVA .250
If I connect 120V to the 460V windings I get 32v on the secondary. which I think is about right for my HobbyCNC board.
First questions is trying to figure out the amp rating on this transformer.
This is how I calculated it from info that I found on the net.
KVA=(A * E)/1000
so that is
.250=(A * 32V)/1000
which gets you A=8.04A
I was not sure if that is correct since the transformer was design for 230/460 primary voltage with a 115 secondary.
Second question, is 8A going to be enough to run the 3 steppers with the hobbycnc board.
Hopefully will have this thing running sometime tomorrow.
http://www.ConceptCNC.com
Old 09-20-2008, 11:08 PM
Al_The_Man's Avatar
At 250VA that means that the normal rating for the secondary is 2amps, The wire gauge may or may not be rated for 8amps.
The same applies to the higher current through the primary.
Old 09-21-2008, 12:23 AM
Well glade I asked. Could you explain how you got 2A from 250KVA? Not really understanding the KVA rating.
Old 09-21-2008, 05:07 AM
irving2008 is on a distinguished road
KVA = kiloVoltAmp i.e. VoltAmp x 1000, so 0.25KVA = 250VA, which at 115V secondary volts = 250/115 = 2.18A. The secondary wiring is probably good for 4A max if the usual derating was applied. Short answer, not really good enough for your needs.
Is it a toroidal (donut) or stack (square) transformer? If the former you may well be able to rewind it relatively easily. I personally wouldn't bother if it was a stack type.
Old 09-21-2008, 09:12 AM
Al_The_Man's Avatar
But even if you beef up the present secondary, you unfortunately will still have a primary that will also have 4x its rated current reflected back from the secondary, when used on 120v.
Old 09-21-2008, 11:08 AM
Thanks for the replies guys. I see now how you get 2A on the secondary. I had misunderstood the KVA formal when it said the E was the Secondary voltage. Had not realized that it was suppose to me the rate secondary voltage and not the voltage that I was trying to get. And ya its a square transformer.
Guess I will be trying the 2 atx power supply trick then. Only other thing I think that i might be able to try is a I have a couple 24V 4.8A PSU that came from some equipment. Is there a way that I could parallel these to get 9.6 amps?
I'm sure that 4.8 is not enough for my motors.
Thanks again for the help guys.
Old 09-21-2008, 01:19 PM
Al_The_Man's Avatar
You can parallel up two transformers, but they have to be very closely matched, or ideally, identical.
If you parallel up the AC you will have to ensure they are phased correctly, there are quite a few previous links on how to do this.
If you parallel the DC you do not need to phase them.
CNC PC Interface and Power Supply Design... Eclipze General Electronics Discussion 19 01-08-2008 12:30 AM
jgro design and electronics? eloid JGRO Router Table Design 4 02-19-2007 05:41 PM
Power supply design Minesgeek General Electronics Discussion 5 12-29-2005 04:31 PM
Power supply design vertcnc General Electronics Discussion 7 11-24-2004 09:25 PM
Power supply design thomasholley General Electronics Discussion 7 04-29-2004 08:18 AM
