Old 10-16-2004, 04:35 PM
NeoMoses's Avatar
NeoMoses is on a distinguished road
Using printer motors and drivers
Has anyone successfully used the electronics from an inkjet printer directly? I'm playing around with a small machine, and these inkjet motors should be sufficient to drive it.
I know I can use the motors alone, with other drivers, but what I'm wanting to do is use everything from the printer (power supply, driver, and motors).
My main question here is: Has anyone ever successfully used a CNC control program such as mach2, turbocnc, etc, through a parallel port directly to a printer and gotten any useful output of the stepper motors? If so, I'm interested to hear your story.
If not, does anyone know software/electronics well enough to make something like this work? It definitely could be a nice way to open up the low-cost, entry level of motion control, since inkjet printers are practically everywhere, and cheap.
My name is Electric Nachos. Sorry to impose, but I am the ocean.
http://www.bryanpryor.com
Old 10-16-2004, 08:33 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
I'm with you mate!
I've salvaged a heap of motors - but my joy sometimes in "dumpster diving" is the salvage - and not the building....
So I too am looking for some inputs on integrating the bits! I'm not too into the electronics end (lets say ----yet) to know how to cobble up a controller - so, I'd be looking for a simple solution for that end. I couldn't even gues HOW to use the built in bits to do the job (embarresed smile)
I think that MACH2 and other progs would do ok - if you can get the controler/driver hardware/firmware to work with the motors!
PS Other bits available from a printer/scanner are the rails, carriages, gears, and all kinds of electric gear - sometimes I feel like a caveman looking at a wristwatch! And all I got for tolols is a hammer!
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 10-17-2004, 04:07 AM
*Registered*
ESjaavik is on a distinguished road
I've heard that in that case all problems tends to look like a nail.
Old 10-17-2004, 09:21 AM
NeoMoses's Avatar
Well, I was playing around with a printer and TurboCNC. I went through all of the possible pin out combinations for step/direction commands, and I couldn't get any reaction from the printer (Epson 777). I think it's time for me to start looking at the Linux world, maybe take a look at any existing open source drivers for these printers. I guess it's time for me to learn some c/c++.
Old 10-17-2004, 09:23 PM
DragnsBane is on a distinguished road
I was also looking into this and found the following site http://www.eminebea.com/content/html...or/index.shtml.
From what i have found the PM55L is the biggest PM motor used in the "home type" printer. It is a 24 volt version, havent been able to find out the amperage yet. but it only has about 17 in-lb of torque at max. Might work if it was fed through a gear reduction. As far as using the printer control panel, you would probably be better off building a board. Just my two cents.....
Old 10-17-2004, 11:44 PM
Sanghera is on a distinguished road
Oh , I just read something about joining some pins on the parallel port and tricking it if a circuit made on it doesn't work. If that makes any sense.
Old 10-18-2004, 03:19 PM
abasir's Avatar
abasir is on a distinguished road
Printers (inkjet/laserjet/dotmatrix/whatever) do not use the standard step/dir signal! There is NO WAY you can configure TurboCNC/Mach2 to make it work without fidling with the electronics/software.
If you want to use them directly, you need to send the 'control commands' and they vary from printer to printers. I've done some work on such 'control commands' before; not too difficult but I was too lazy.
Here's what you need:
1. G-Code to Control Commands Translator
2. Sending Control Command to Printer
Does the above make sense
Stupid questions make me smarter...
See how smart I've become at www.9w2bsr.com ;-P
Old 10-18-2004, 03:36 PM
abasir's Avatar
On 2nd thought, you could make it to work IF you could trace and identify the step/dir signals on the PCB and directly connecting it to the parallel port (bypassing the printer controller). Trace the wires from the steppers to the board, follow the trace to the driver ICs, identify the ICs (google it?) and take it from there....
Old 10-21-2004, 06:30 PM
NeoMoses's Avatar
hmm, good information. I'll keep looking into it.
Old 09-28-2005, 11:28 AM
NeoMoses's Avatar
http://en.wikipedia.org/wiki/Printer_Control_Language
and another:
http://printers.necsam.com/public/pr...des/pcl5hp.htm
  #11   Ban this user!
Old 09-28-2005, 11:58 AM
greybeard's Avatar
greybeard is on a distinguished road
Neo - I, too, would very much like to follow up this idea, and I'm sure a lot of others would admit the same.
I looked at your links in the last post, and noticed the encouraging statment in the first one " PCL output can also be easily generated by custom applications." I take this to mean that the basic idea is "ok to go".
Also noted that the pcl's are universal to all printers, so any method that gets us into one type should be of general application.
I'm going to have to print out the pages though to absorb some of the info, having no programmi ng experience. I'm strictly a discrete component man trying to keep up with ic's, never mind telling them what to do.
  #12   Ban this user!
Old 09-28-2005, 03:46 PM
NeoMoses's Avatar
and another... it looks like I might be getting warmer.
http://support.microsoft.com/kb/q154078/
Staggering motors viktorcnc Stepper Motors and Drives 12 10-12-2005 04:56 AM
Worth a Thousand Words Chunky General Electronics Discussion 41 05-29-2005 04:18 PM
Have existing stepper motors but want to replace control board with integral drivers. Gerald_D General Electronics Discussion 3 05-22-2005 09:55 AM
Help picking drivers sinnedD Stepper Motors and Drives 5 03-12-2005 09:42 PM
Need help with staggering motors viktorcnc General Electronics Discussion 0 07-05-2004 04:42 AM
