Old 09-07-2008, 10:57 AM
honda is on a distinguished road
Wells Index Mill
I have a Wells Index mill with 575 voltage -- can I convert it to 220 and have the motor rewired. If not what is the best way to hook this up in a residential garage?
Horsepower is 1.5 RPMs 1800, 1.75AMP, PH3CY60, model MB8461-X.
Any help will be greatly appreciated.
Old 09-07-2008, 11:03 AM
Al_The_Man's Avatar
Most likely most of the control electrics will be sourced from 240/120vac, so if you only have one three phase motor, then look at replacing it with a 220 3phase motor and use a VFD for conversion from 1ph to 3ph, you will also have speed control, if it does not already have.
Feed the machine from a suitable 240v 1phase outlet, you may have to remove/change a control transformer or two.
Check for any other 3phase devices though.
Old 09-07-2008, 12:54 PM
wells Index mill
as I can see thire is only one motor I will sent some pic of the mill
Old 09-07-2008, 01:17 PM
wills Inder mill
as I can see thire is only one motor-but I have sent some pic of the mill if you could take a look at pic I post themon the site
Wells Index Mill mystery knob...What's it for? Chris64 General Metal Working Machines 3 10-01-2008 11:56 AM
Repairing or retrofitting a Wells Index Aley General Metal Working Machines 13 09-04-2007 04:03 AM
Wells-Index Z-Axis Replacement Gear askjerry General Metal Working Machines 2 08-06-2007 11:19 AM
Wells Index model 747 wall!@# Knee Vertical Mills 0 04-27-2007 02:17 PM
Wells Index cnc iron ....FREE...but gus Bridgeport and Hardinge Mills 0 11-16-2005 12:13 PM
