Hi Folks, Okay, so I've spent the last couple of days asking tons of questions about transformers, and reading as much as I can find on the subject that I can understand at this point. So yesterday morning, I felt I had a brake-through in my understanding of how transformers and electricity works, at least for the cnc system I'm building. (HobbyCNC Pro kit) I was pretty nervous about using a transformer with more than the called for amperage (10A) until I finally understood that the amperage would not be a factor as the stepper motors would only require so much, their rated at 3A each, and that a transformer would not deliver a continuous amperage unless it was called on to do so. So I make this post in the group forum to verify that I am totally understanding how all of this stuff works, and that it would be ok to use a transformer that's rated at a higher amperage than the 10A's the kit calls for, because as stated above. I got two or three replies that I had finally got it, and was thinking along the proper lines. Then, later in the day, the owner posts that if I were to use a transformer that a buddy of mine has that's rated at something like 35 volts and 50A's, that it would smoke the board! After this, another poster comments on some details that I was not aware of, such as that the transformer, although only puts out or is rated at 35 volts, would actually produce much more than that, and that would fry the board. So, now here I am lost again, and trying to figure this stuff out... OK, the HobbyCNC board says that you can use a power supply up to 42 volts. Yet the 35 or 40 volt transformer would go beyond this and fry the board. I don't get it. Also, it was made very clear to me, that I was not to exceed the 10A limit or again, smoke would roll. With all of that said, am I to understand that the recommended transformer of 24 volts and 10A's will actually exceed that 24 volts, and shoot upwards of 32+ volts at any given time during operation? And, the amperage that a transformer puts out, although will not be there unless the system starts calling for it (pulling it?) , will still burn up the system anyway because there's to much power (or push)? I thought I had a grasp on this transformer stuff, but I'm feeling as lost as ever after this day. Any insight or input is welcome. I also have two microwave transformers that I was holding onto for a future build of a cnc machine (one I have already rewound at 19.2 volts) and what must be 40 or 50 amps I would think. But after getting the responses I've gotten, those are probably useless for anything more than boat anchors now. Thanks, Patrick |
Not quite accurate. Also, it was made very clear to me, that I was not to exceed the 10A limit or again, smoke would roll. The transformer voltage you intended to use will smoke the board. The RECOMMENDED transformer is 24VAC 10A. No one said additional AMPS will smoke it. As suggested, www.mpja.com has a 24VAC 10A tranny for @$20. Simple and cheap. AC volts is quite different than DC volts. An easy mistake for a newbie to make. |
But the TXFR is CAPABLE of 100amps if it was required. It would just be overkill in sizing. Al.
| OK, so, if the transformer is rated at or below 24 volts for the HobbyCNC system, then the amperage is a null subject? Please remember that I am new to this stuff, so I am likely to misunderstand peoples responses to me until I gain the knowledge and experience needed. With that being said, one of the reasons I purchased a kit instead of a turnkey solution, was because I wanted the experience of learning this electrical stuff, and even though it may be less expensive and faster to just go out and buy xx product, rather than build it myself, I am a do it yourself'er, and part of feeling I have a reason to exist is figuring out things like this. It reminds me of something my Dad used to say to me all of the time... For example, back when I started to drag race years ago, I purchased a car where I needed to build everything myself, such as the roll cage, engine, and all of that stuff, and my Dad would say: "Why didn't you just buy one that's ready to go so you could save some money in the long run?". My response was always: "But what's the fun in that?" Not only did I want to drag race, I also wanted to know every nut, bolt, and wire in that car, I wanted to feel as though a part of me was invested into it. Had I known at that time that I could have ripped apart a couple of microwaves and built my own arc welder for pennies, I would have built that too instead of buying one. Not only would I learn how to weld, but learn how to build the darn welder to boot! Same goes for everything I do. I did purchase the recommended transformer for the HobbyCNC kit, and am using it, but I still want to learn how it all works, and I want to know enough in that manner, that I can eventually do whatever I want, and can do it because I've gained the knowledge to be able to do that. For example, I have a ton of digital displays from microwave's I've taken apart, along with a pile of other electronics that I know nothing about, but am looking at and have ideas of what I might use them for in the future. I was thinking that someday I might add a couple of digital displays that would show me in real time what the current voltage is from the transformer, as well as current amperage being drawn. Sure, for the average person like my Dad who just wants to get the job done in the fastest amount of time, that's a waist in effort and energy, but for me, it's all in the art of learning what's going on in life. So, I apologize if I misunderstood what someone stated, I'm a newbie and learning as I go. But it also warms my heart to know that I am in fact getting a grasp on understanding the whole amperage deal as well. So I am right in thinking that amperage is likened to a muscle builder, although he may have all of that muscle, it doesn't necessarily mean that he uses it in everything he does, but it is available if he needs to pick up my new big block 540 Chevy and stuff it in-between the fender rails of my race car for me. ![]() Thanks, Patrick |
If you want to brush up on fundamental Electrical/Electronics, there are many web sites that offer basic instruction. Al.
I don't know how to explain it, but when the AC voltage is converted to DC at the bridge rectifier, it's multiplied by 1.4 times (I think). So your 40V transformer will give you 56V DC.
| Hi Gerry, Does that apply to all bridge rectifiers in curcuits such as these? I mean, is that a calculation that I can use to figure out how things are going to work in any given cnc system I might build in the future, regardless of what bridge the kit might be supplied with? (110AC Std. Wall Current) If so, I will remember and use that in the future. Thanks, Patrick |
| If you build a DC power supply using a transformer, bridge rectifier and capacitor, than yes.
#10
| This might help you out. http://campbelldesigns.net/files/pow...ply-part-1.pdf
#11
| OK, I tested my 19.2 volt transformer, and after it goes through the bridge and cap., it's up to 28.3 volts! That's a 1.4739 increase in voltage. It's strange that it would actually boost the voltage, although pretty cool at the same. Now I will have to study to learn why this happens. ![]() So, it is a good thing I didn't hook up that 35-40 volt transformer, or there surely would have been smoke. 8-O Thanks, Patrick |
#12
| Nice ebook, thanks. The one thing that he doesn't explain in there is way the amperage "should never exceed" about 67% of the total of the stepper motors? This is where it gets back to having to much amperage is a bad thing, and what makes it confusing to me. In one place, people will say that you don't have to worry about the amperage if you're over what the system calls for, then in another place we're told to never exceed a certain amount. For example, one of my microwave transformers I've rewired that delivers 19 or 20 volts, has got to be pushing the upper limits of 40 or 50 amps I would think? In this case, these transformers would not work with a CNC driver board. Yet, I read where there are people using these very types of transformers to power their CNC systems. So what gives here? Are we looking at a case where these people are basically living on borrowed time and it's just a matter of the right circumstance and they're going to fry their boards or something? Thanks for any feedback, Patrick |
| CNC mill questions - thrust bearings, leadscrew mounting, general questions | tonofsteel | DIY-CNC Router Table Machines | 8 | 02-03-2012 03:42 PM |
| Brass vs Aluminium Vs Steel, questions, questions and questions... | alexccmeister | General Metal Working Machines | 25 | 08-15-2011 12:40 PM |
| 220 to 400 V Transformer | DennisCNC | General Electronics Discussion | 15 | 12-15-2010 12:08 AM |
| One big transformer or three? | koslaz | General Electronics Discussion | 4 | 10-13-2006 07:06 PM |
| Transformer | CapnC | General Electronics Discussion | 10 | 01-03-2005 09:27 AM |
